95 RRC TWR - 83k original miles - Defender Source
Old June 29th, 2012, 01:57 PM
98 HOO's Avatar
98 HOO
Josh Smith
1960 Series 2a/D90 Hybrid
I am selling my 1995 RRC TWR with less than 83k original miles. It recently had the engine rebuilt and runs well. . I just bought this a couple months ago and have quickly realized that it is redundant to my '04 Disco. I also feel like it is too unique/nice to modify/play with and I hate to put the work into completely restoring it to not drive it. I am asking $6,200.00 and am taking a loss on it at the asking price. I have put a bunch of pictures at http://s1076.photobucket.com/albums/w446/smithjoshu/ if you want to see something else specifically, please let me know. I have driven it about 200 miles in the time I have had it and it is being kept in the garage. Truck is located in Chester, VA about 20 minutes south of Richmond.
More info on the TWR about ¾ way down this page: http://www.rangerovers.net/modelspecs/1995.html
Good
Very recently rebuilt motor - very tight and clean – haven’t seen any leaks. Previous owner had passed away and I bought it from his son - I don't know why it was rebuilt. Looks to have had a new water pump and alternator at the same time.
Interior is clean - leather in good shape except drivers seat cushion which has some cracking, but no tears.
Upper tailgate in great shape.
All electrics work with exception of cruise control (hoses split), light at a/c controls, and possibly heated seats (lights come on, but it has been warm since I got it, but I don’t think they are working)
Headliner is in good shape.
No warning lights on the dash
Air suspension removed and springs installed.
Brakes work great with no pulling or shuddering.
No leaks from transmission, t-case, differentials, etc.
Just passed Virginia inspection in April.
New Michelins
Air conditioning blows cold.
Surco ½ rack installed.
Not so good:
The hood had an ornament mounted on it, so there are two holes in the hood. The hood needs to be repaired/repainted. No rust, just the holes and some oxidation. I put black rivets in the holes when I received the truck.
Swivels are weeping
Dent in roof at back right corner - body shop quoted me an hour and a half to repair. Small dent in back of right rear fender (both in pictures)
Dent in left rear fender. The dent looks minor (shown in pictures), but the body shop said it might be easier to replace that fender.
Some rust at license plate lights and at either side of tailgate (in photos). Some very light surface rust at the vertical portion of the rear door jambs. Some rust in the passenger side footwell – I scraped off anything loose to take the picture in the attached link.
Some scuffs on bumpers as shown in pictures.
Solenoid won't allow t-case to shift into low – didn’t get around to removing the solenoid.
Old June 29th, 2012, 02:42 PM
PM sent!
Old June 30th, 2012, 09:02 PM
draaronr's Avatar
draaronr
Here
LR3
i've had a few of these, nice trucks
Old July 1st, 2012, 12:29 PM
98 HOO's Avatar
98 HOO
Josh Smith
Autocheck from when I bought it.
Your Vehicle Checks Out! AutoCheck examined the reported odometer readings reported to AutoCheck for this 1995 Land Rover County Classic (SALHV1240SA659776) and no indication of an odometer rollback or tampering was found. AutoCheck uses business rules to determine if reported odometer readings are significantly less than previously reported values. Not all reported odometer readings are used. Title and auction events also report odometer tampering or breakage.
0 Problem(s) Reported: Mileage Date Reported
image 15,196 12/20/1996
image 44,000 07/11/2000
image 55,000 03/05/2002
image 57,434 06/20/2002
image 57,785 10/29/2003
image 68,545 01/04/2005
image 77,000 06/19/2007
image 77,001 09/24/2011
Below are the historical events for this vehicle listed in chronological order. Any discrepancies will be in bold text.
Report Run Date 2012-04-12 17:41:35.768 EDT
Vehicle: 1995 Land Rover County Classic (SALHV1240SA659776)
Event date Location Odometer reading Data Source Details
02/12/1996 OTTAWA, IL
Motor Vehicle Dept. TITLE (Title #:T6065285011) (Lien Reported)
02/26/1996 OTTAWA, IL
Motor Vehicle Dept. REGISTRATION EVENT/RENEWAL
12/09/1996 CHICAGO, IL
12/20/1996 CHICAGO, IL
15,196
Motor Vehicle Dept. TITLE (Title #:T6355367022)
06/27/1997 CHICAGO, IL
05/19/1998 CHICAGO, IL
03/11/1999 CHICAGO, IL
06/29/2000 CHICAGO, IL
07/11/2000 CHICAGO, IL
44,000
State Agency PASSED EMISSION INSPECTION
03/05/2002 CHICAGO, IL
55,000
06/20/2002 CENTRAL REGION
57,434
Auto Auction REPORTED AT AUTO AUCTION
10/29/2003 TULSA, OK
57,785
Motor Vehicle Dept. TITLE (Title #:722603302002)
03/24/2004 OMAHA, NE
07/06/2004 OMAHA, NE
01/04/2005 SANTA FE, NM
68,545
Motor Vehicle Dept. TITLE (Title #:05004334G718211)
01/03/2006 SANTA FE, NM
01/22/2007 SANTA FE, NM
06/19/2007 TESUQUE, NM
77,000
Motor Vehicle Dept. TITLE (Title #:071702S01805771)
05/07/2009 TESUQUE, NM
06/02/2010 TESUQUE, NM
09/24/2011 SANTA FE, NM
77,001
Motor Vehicle Dept. TITLE (Title #:112673S01767667)
12/02/2011 GULF BREEZE, FL
Old July 6th, 2012, 08:54 AM
98 HOO's Avatar
98 HOO
Josh Smith
Bump and Price Reduced - $5,800
Thanks.
Old July 19th, 2012, 07:34 AM
98 HOO's Avatar
98 HOO
Josh Smith
I am lowering the price to $4,500 FIRM!
I feel that this is a very good price - doesn't even pay for the engine re-build and the new tires.
Reasons for the reduction - When the motor was rebuilt, they routed the kickdown cable against the exhaust manifold - I hadn't noticed until it froze up the other day. I have disconnected it so it will drive fine - you would just have to downshift manually if needed at speed. The cable will need to be replaced. I also noticed that on the highway, if you let off the throttle, the truck will pull slightly to the right - wheel bearing, ball joint, or suspension bushing? Lastly, it looks like I landed a new project (work) about 96 miles from home so I need to look into a commuter car soon.
Old July 19th, 2012, 07:43 AM
Wow very nice! Someone quick - buy this before Wolf does!
Seriously looks awesome.
Old July 19th, 2012, 09:30 AM
Wolf Fabrication's Avatar
Wolf Fabrication
Sterling Archer
'08 D3
Back off vultures!
I am actually going down to see it Saturday morning.
Semper Fi!
Old July 19th, 2012, 09:31 AM
draaronr's Avatar
draaronr
Here
LR3
Originally Posted by Wolf Fabrication View Post
Back off vultures!
uh oh, these trucks are super classy, enjoy my guess is you'll take it home.
Old July 19th, 2012, 09:44 AM
Wolf Fabrication
Sterling Archer
'08 D3
It has a little rust and needs some love like all RRCs do, but looks to be a decent candidate.
Semper Fi!
Old July 19th, 2012, 10:02 AM
Abrooks's Avatar
Abrooks
Tony Brooks
for a few bucks you can get a generic silicon hose set from summit racing with which you can fix those cruise control lines. Cheap and easy fix!
Old July 19th, 2012, 10:16 AM
Wolf Fabrication
Sterling Archer
'08 D3
Fixing that kickdown "cable" issue is a bitch though. You have to drop the tranny pan and throttle body.
Semper Fi!
Old July 19th, 2012, 03:43 PM
98 HOO's Avatar
98 HOO
Josh Smith
Wolf is passing - still available - let me know if you are interested or have questions.
Thanks.
Old July 20th, 2012, 07:41 AM
Roving Beetle
Doug
Want to trade for a nice clean 2002 Jetta? Great commuter.
Series coiler monster in building process, in gather parts mode.
Currently driving an ex-southern 1993 SWB RRC with too much "kit". Massive conversion and interior swap in process.
Lots, lots and lots more have come and gone....
Old August 6th, 2012, 08:34 AM
98 HOO's Avatar
98 HOO
Josh Smith
Sold locally on Craigslist - Thanks.
Old February 9th, 2015, 09:57 AM
WeBeCinYa's Avatar
WeBeCinYa
WeBeCinYa
94 ST #84
Now with plasti dip body...you were right Josh. From my perspective that just slashed value...
http://washingtondc.craigslist.org/d...883393482.html
Old February 9th, 2015, 10:04 AM
Someone is reaching a little.
1995 Range Rover County Classic - $8800 (Tyson's Corner)
A classic, 1995 Range Rover County with 93.5k original miles. This truck has the famed TWR/ Brooklands package which rumor has it that only 8 still exist in the United States. Just had the body plasti dipped (1000 bucks) to help preserve the original paint and at the same time had the 90k mile service done (1580 dollars) which drops all the fluids, full tune up and all new filters. Truck was gone over by Loudoun Rovers with a fine tooth comb. Michelin LTX AT tires have 90 percent tread, new brakes and new inspection. This is a solid rover, but it is a 1995 and will need to be kept up with. I drive it a couple times a week on the highway but it sits in my heated and cooled barn most of the time. If you know these trucks, they will literally go anywhere. Quite possibly the best 4wd ever made. No low ball offers will be responded to.
Old February 9th, 2015, 10:26 AM
cellulararrest's Avatar
cellulararrest
Chris Snyder
1994 D90 #614 | '07 L322 SC
I dunno if they're really reaching much, honestly. Around 7k might feel a bit better, but she looks to be in pretty good shape. Fixing the rear body rust would go a long way though.
And the plastidip peels right off
Old February 9th, 2015, 10:33 AM
I meant the whole only 8 TWRs left in existence.
Old February 9th, 2015, 10:34 AM
cellulararrest
Chris Snyder
Ah. Well that is supposedly true.
95, original
1995 defender LHD 110 hicap pickup diesel 14,000 original miles haaseizhere For Sale - Vehicles 18 January 4th, 2017 05:11 PM
95 RRC goodies (some DI & RRC crossover) RoverDude For Sale - Parts 4 August 24th, 2010 03:19 PM
'95 RRC TWR edition for sale - Denver, CO Art Vigil For Sale - Vehicles 70 August 20th, 2010 06:21 PM
1997 D90 SW w/ 20,000 Original Miles Defender37 For Sale - Vehicles 8 February 19th, 2009 08:44 AM
OIL...oil...oil... norros Defender Technical Discussions 20 August 22nd, 2004 01:30 AM
» Defender Registry
D90
NPT90
Garth II
Ferniekids
Add your Defender
