94 Defender 90 red - Defender Source
Old January 11th, 2010, 09:53 PM
mstrjake138
Norman Wagner
1994 Defender 90
94 Defender 90 red
94' Defender 90 for sale $20,999 obo
Thank you for your interest. The mileage is approximately 73895(original)miles,I am the second owner. I purchased it approximately 1 1/2 yrs ago in Georgia. I bought it from Bear Valley Auto sales(Georgia) and they had purchased it from the original owner(also from Georgia) at that time. I am sorry but I was unable to obtain history records from the dealer.
There are two minor oil leaks, one from the rear main and the other is in front of it. If you know Landy's you know they tend to be leaky. I owned a Disco before this and it leaked a lot more. As far as Landy's go this D90 leaks minimaly. I have not had to add oil between changes(every 3000 miles). No coolant leaking. I have a mechanic in my area that is a 4x4 enthusiast and he gave it a thorough once over to let me know what needed fixing on it. As far as mechanical, he(my mechanic) found that it will need a new clutch($1500), however the clutch is still in working order, the clutch pedal does have a bit more play than is desired. The transmission is the LT77(Military version), it shifts well but the reverse gear is up and to the left. Different from the later 94' models which were the civilian model(R380). I replaced the rear shocks with Rancho 9000 adjustable, however the front shocks($500-Bilstein shocks were recommended) do need to be replaced. The two minor oil leaks($100). My mechanic said he could repair/replace these items for the prices listed with each. I was intending on replacing the clutch w/ a friend to save some $$, but my priorities have changed. The only other item that needs replaced is the rear wishbone link, which I have a xerox copy of the item and number from Landy(they are a bit reserved at giving the information out and will not sell copies of the mechanics book). I was told it was approximately a $200-300 replacement and a bit cheaper if you did it yourself.
I recently purchased an original LR fiberglass top for it. It is in rough shape but does not leak. As far as the soft tops go. The full one is a Badger-w/ rain gutter/metal fasteners(the rear window panel has a small separation in the zipper and window-$50 repair). The bimini($300 value) and Bikini($150 value) are in great shape. The AC works great and so does the heater. It is a great 4x4 as you know and would make a wonderful edition to any off-road enthusiast's quiver. I am asking $20,999 obo. Let me know if interested. I am located in southern Colorado.
Cheers
ID:	24277   Click image for larger version
Old January 12th, 2010, 07:56 AM
Just FYI, anyone interested here will want to see close up pictures of any rust areas. Search the for sale section if you don't know where those are. You'd be best served showing pictures of the tops as well.
Best of luck with the sale.
Old January 12th, 2010, 12:53 PM
mstrjake138
Norman Wagner
1994 Defender 90
Thanks. I was only able to upload a few pics with the thread. It wouldnt let me do anymore than that. So I am working on getting the pics on here or a site that u can goto to see the rest of the pics. It does not have very much rust,especially in the trouble spots
Old January 12th, 2010, 01:46 PM
You went to advanced and use the "Manage Attachments" button? You should be able to do 10 at a time, and I am not aware of any limit on the number.
You will need to resize them to 1024x1024 if they are .jpeg (or see the chart on the upload page for the size restrictions)
90, defender 90
Very Nice!! 1995 Red Defender 90 for Sale vbryan For Sale - Vehicles 2 May 6th, 2005 12:37 PM
1994 Portofino Red Defender 90 WhiteD90 For Sale - Vehicles 11 March 15th, 2005 06:23 AM
1994 Red Defender 90 for sale BrianConway321 For Sale - Vehicles 5 February 22nd, 2005 09:27 PM
94 defender 90 w/ 27k miles ebanks For Sale - Vehicles 5 September 8th, 2004 01:05 PM
