'93 RRC LWB rare blk on blk. NO ROT or RUST! LT230, Mallory dizzy, GM alt, SOLID! - Defender Source
Old August 13th, 2013, 12:57 PM
Roving Beetle
Doug
Ok - so I just got this, saved it from being parted out. To anyone wondering and wanting to be an ass - yes I bought it cheap. Yes I towed it home. Yes I put a lot of time into cleaning it up and going through it. Yes I diagnosed the issues and spent my time getting it reliable again. YES I plan to make a few bucks on it. Welcome to the capitalist country we call America.
Had a bad pickup in the Mallory distributor - repaired and runs great.
SUPER SOLID rust free body and chassis.
Now.... It is a Rover. It's RUST FREE in terms of typical rust. Does it have SMALL spots and LIGHT surface rust in confined areas - OF COURSE.
That said there is NO rust through and no issues with corrosion. The floor boards had minor surface rust from the normal wet padding. No issues. It's been sealed with Wurth poly cure rust paint. (Like POR15 but better)
Has not been painted on any panels ever so far as I can tell. So what you see is truly what you get. Dings here and there but overall VERY presentable.
Interior is quite clean - however:
NO headliner at all.
Rear seat has one large tear in the pass lower corner.
Missing a couple trim parts like 1 A-pillar and both front door thresholds.
Ignition key was inop so it has been wired with toggle and push button.
(I will include a good key set-up if desired)
Rear load space carpet is missing.
Rear load space cover is missing.
Radio code missing so I don't know if it works.
Outside:
Dings and few scratches for sure but no big issues save for:
Crease in center of front edge of bonnet.
Crease in rear lower gate almost center above license plate light.
SLIGHT corrosion on lower gate near license plate light. MINOR. And no other corrosion around gate or rear lights area!!
Upper tailgate is so-so. Should be replaced but its there and holding fine. Holding too well... The latches seem to be stuck. Have not tried too hard to open it. Closed currently.
Both drivers side chrome bumper finishers are missing.
Small chip in windscreen near center. Not in view and NOT bad at all.
Clear coat is bad on hood center and roof. Colorado and then southern truck....
Wheels are excellent with only minor scuffing/curb rash.
Tires are near new BFG commercial TA. 245-75-16
Brakes are good and front caliper recent.
Brakes work well, NO ABS LIGHTS ON. Functions as should.
No check engine lights.
All lights work. All functions work INCLUDING AC.
Power mirrors are hit or miss.
NEW BORLA CAT BACK.
Mallory dizzy and coil.
GM alternator conversion.
Tach sometimes works.
LT230 transfer conversion with good ujoint shafts front and rear.
No cooling issues.
Recent new steering box. Still has slight reservoir leak though.
OME lift springs and shocks. Rides great. Slight wander due to drive angles (normal and feels fine to me)
No big noises - few rattles here and there of course.
May have a slight exhaust manifold or header pipe leak as I can hear a slight tick-tick leak.
Recent battery.
New wiper blades beam style.
Seems to run drive and stop fine. Since I have not driven it that much I'd recommend towing any great distance, it has sat for some time - but I'm driving it everyday and it goes well. Just needs a bunch of detailing to be excellent. But the solid body..... It's a GREAT platform to start with!
If I can't sell her soon I will build this truck back to what it should be. A great daily and mild trail toy. I like it a lot, the black interior is nice!
Open to offers and swaps of course but given the rare not-rotted-with-brown-cancer here in Maine nature - I'm asking $4000.
Series coiler monster in building process, in gather parts mode.
Currently driving an ex-southern 1993 SWB RRC with too much "kit". Massive conversion and interior swap in process.
Lots, lots and lots more have come and gone....
Old August 13th, 2013, 01:05 PM
EWR's Avatar
EWR
Carey
1954 CJ-3B
I will second it's a solid truck. I've looked at this in person and I can say this was not a Maine truck.
What tree?
Old August 13th, 2013, 01:08 PM
Roving Beetle
Doug
Carey - I figured you'd try and sabotage the sale... Since you want the truck so badly. Ha ha.
You and I both get pulled in by shiny things that don't have rusty cancer. "Like a Crow"
Old August 15th, 2013, 02:26 PM
Roving Beetle
Doug
I am shocked nobody wants a rot free solid black on black LWB....
Open to offers. I need cash or parts for the series hybrid coiler build.
Doug
------ Follow up post added August 15th, 2013 02:27 PM ------
Kinda want to swap the 4:43 gears and Detroit in it and toss the 285 swampers on.... Ha ha ha
Old August 16th, 2013, 02:21 PM
Roving Beetle
Doug
An update, did some more work to her today.
I have floor sill covers for it, a fuse panel cover and a whole spare ignition column with wiper/turn stalks etc. I will include these parts.
Tightened up the manifold bolts and no more exhaust leak tick issue.
I believe one of the cats *may* be rattling - heard it when cold. I will include another y-pipe assembly with purchase.
Repaired a rear control arm bushing, drives far better now.
Still needs a new upper A-Arm ball joint, does have some play and can hear slight clunk every so often from the rear. It's not horrible by any means and I'd drive it to florida as is personally. I can include a spare joint with purchase.
Now that she's back on the road a bunch the swivel ball seals are weeping. Not horrible, but there is some wetness. Just want a full disclosure. Also as mentioned the steering box is NEW but the res or line to the res still leaks a little. Again, not horrible, but there.
Center console arm rest is missing - will include one with purchase.
If someone wants to drive the truck home any distance there is a good spare tire, jack set and I would be happy to pick you up at the local airport. I will also purchase another new Mallory Distributor pick up sensor as they are a known weak point in the system. ($50 on Amazon)
And I will top off the fuel tank for you.
Oh and if it sells via here on the forums for a reasonable price I will donate $200 to the site... is that fair? Do we have a donate button somewhere?
Doug
_________
Old August 16th, 2013, 09:58 PM
Roving Beetle
Doug
Stay tuned - truck may be sold semi locally.
Not sure 100% so feel free to PM or email if interested, but she may have found a new home.
Old August 17th, 2013, 12:57 PM
Tempting, has it lived in the Northeast its entire life
Old August 17th, 2013, 02:28 PM
Roving Beetle
Doug
No - as said above its a Denver CO truck.
Old August 17th, 2013, 02:47 PM
REDrum's Avatar
REDrum
Niall Johnson
1970 Series IIA 88 - Sandstone
VERY good deal. GLWS!
Toltec Coffee Team:
'99 UZJ 100 - for glamping and grocery getting
'94 FZJ80 - our Costa Rican coffee mule
'96 FZJ80 - 3XL, racked, shaved and dipped in Raptor coat
'70 Petrol SIIA 88 - a Costa Rican expat now with US citizenship!
'70 Petrol SIIA 88 - for Central America surf & coffee exploration
'56 Petrol S1 86 - a whole new kind of land rover hell...
Old August 20th, 2013, 09:34 PM
Roving Beetle
Doug
Sold locally...
Old September 10th, 2013, 10:56 AM
Roving Beetle
Doug
EDIT: deal may have fallen through on this truck. Buyer decided he wants a pickup..... Mainer's and their pickups.
Sorry for the confusion - contact me if you're interested! Thank you. Doug
Old September 10th, 2013, 11:32 AM
Doug that truck sure does show a lot of 1994 features. The Dark Sable Connolly Leather interior with the Beluga Black clear coat was specific to 94 LWBs. 1993 only had Saddle leather interior. That and the Cyclone wheels with the logo center caps.
Does it have black plastic door sills?
I bet if you yanked an axle out it would be 24 spline.
Old September 10th, 2013, 11:59 AM
Roving Beetle
Doug
07/93 build date. So she may be... But it's been registered as a 93. Oh well.
Old September 10th, 2013, 07:22 PM
Roving Beetle
Doug
More pics - a little wet today if things look odd. And the flash makes it weird. Anyway...
Old September 13th, 2013, 05:33 AM
Jim-ME
Jim Ecker
1964 Series 2/2a bitsa
I too have seen this Rover and it is a beauty. Doug is describing it perfectly.
Jim
Old September 13th, 2013, 07:45 AM
Roving Beetle
Doug
Thanks Jim. You really should have it.
Old September 17th, 2013, 04:04 PM
red64chevelle
Daniel Smith
86 110 300TDI,16 Disco Sport
I thought I had a buyer for my mk6 TDI, but he could not wait for me to get back from sea (I don't blame him, life moves on).
If I sell it before you sell yours I would love to check her out.
75% of all Land Rovers ever made are still on the road...
the other 25% at least made it home.
Old September 17th, 2013, 04:39 PM
Roving Beetle
Doug
I like TDI's - trades are possible.
Old September 17th, 2013, 04:56 PM
red64chevelle
Daniel Smith
Well, take a look at my FS post
http://www.defendersource.com/forum/...ad.php?t=46374
Let me know if we should meet up.
Old September 18th, 2013, 08:41 PM
Roving Beetle
Doug
Too new for me. Only my wifey drives cars that new and nice.... She keeps them - I sell to often so it makes more sense for me to have older jalopies.
lt230, lwb
RRC stuff - Breaking 93 LWB o2batsea For Sale - Parts 28 December 25th, 2012 12:33 PM
95 RRC goodies (some DI & RRC crossover) RoverDude For Sale - Parts 4 August 24th, 2010 03:19 PM
93 rrc lwb landrovered For Sale - Vehicles 10 May 3rd, 2010 09:16 AM
'93 Range Rover LWB tbmcneill For Sale - Vehicles 2 January 8th, 2004 01:36 AM
