85 110 3 door truck cab $12,500.00 - Defender Source
Old September 19th, 2014, 07:32 AM
Capt Milks's Avatar
Capt Milks
Defender V-8, Defender 2.25
I have a 85 110 truck cab that I would like to sell. It has the 2.25 NA Diesel. It is a RHD truck. The good...the truck runs and drives out pretty well. It has a smooth transmission and the engine starts right up. Glow plugs work! I have taken it for short drives on the highway and it drives out pretty darn good. The transfer case shifts as it should. The Bad... the frame looks solid but has had a ton of repairs. It has welded patches and a few new outriggers. But all in all it is pretty solid. The rear cross-member could be replaced or patched. The bulkhead looks pretty good with one footwell repair and it will need a little more attention but not a basket case. Somebody has stood on the roof and it needs to be beat back flush. The body is rough but not outrageous. The rear tub has two gashes, one on the inside wheelwell one on the LH rear fender. It was used on an estate in England and looks the part. The inside is OK with the older, series style, seats. The electrical, glass fuses, looks sound. New lights at the rear. LF turn and running light are not working. I think it is the ground but haven't had time to check. Spedo is not working. (could just be the cable)
This would be a great starter or trail truck. Asking $12,500.00 OBO with a Virginia Title. email me for more information and pictures. I can deliver to MAR if needed.
Name:	Red 110 Pu.jpg
ID:	103188   Click image for larger version
Name:	Red 110 pu inside.jpg
Name:	Red 110 Pu engine.jpg
Old September 19th, 2014, 07:53 AM
Check the wanted ads. Could have sworn that someone was looking specifically for a single cab 110 in the US within the past month.
Old September 19th, 2014, 08:21 AM
Capt Milks's Avatar
Capt Milks
Thanks, will do
Old September 19th, 2014, 09:36 AM
Found it if you had trouble.
http://www.defendersource.com/forum/...ad.php?t=55293
Old September 19th, 2014, 01:14 PM
Capt Milks's Avatar
Capt Milks
Emailed him, Thanks for looking it up.
Old September 23rd, 2014, 07:10 AM
Capt Milks's Avatar
Capt Milks
Bump to $12,000.00. I can also re-build the truck with a V-8 conversion if interested.
110, door
land rover 110 truck cab :: 1990 Land Rover 110 sakis Defender & Series Truck Registry 0 March 9th, 2014 09:45 AM
500/500 bjf Misc. Chit-Chat 19 January 28th, 2013 01:01 PM
Defender 110 Hi Cap Bed and Truck Cab FS SafariHP The Vendors Loft 2 April 14th, 2009 06:34 PM
110 Truck Cab Firewall for HI Cap SafariHP The Vendors Loft 2 February 23rd, 2009 09:01 AM
90/110 Truck Cab SafariHP The Vendors Loft 11 February 23rd, 2009 08:55 AM
» Defender Registry
#304
TRS
Kalahari
Desert Lion
Add your Defender
