72FL64 Forward Control GS - Defender Source
Old October 29th, 2015, 11:14 AM
johnny3rovers's Avatar
johnny3rovers
John Holmes III
1965 Series IIA
Only one coat of paint! Ground up restoration by a military vehicle collector. New Exmoor Hi-Back seats. New Exmoor canvas. New clutch. Numerous spares, including two manifolds with five Stromberg carbs. All details addressed. Featured by John Craddock, Ltd.
$32,000
More pictures provided to serious prospective buyers.
I'm ready to start a Series 1 project. This one is pretty much done!
John Holmes 865-382-7624
Name:	101 small.jpg
ID:	133394   Click image for larger version
Name:	101 front axle.jpg
Name:	101 rear axle.jpg
ID:	133396   Click image for larger version
'00 Disco, a beast!
'95 RRC LWB, slowly rusting away.....
'65 Series IIA, 88, a gem!
'76 Forward Control GS, 72 FL 64, a real beast!
Old October 29th, 2015, 07:09 PM
roverguy's Avatar
roverguy
Robert
1995 RRC
That's awesome! Where in Knoxville are you? The only thing keeping me from buying this is my wife... And $32k!
1965 IIa 88
1995 RRC 25th Anniversary
98 Discovery LE7
2000 DII (SOLD)
Old October 30th, 2015, 06:53 AM
johnny3rovers
John Holmes III
1965 Series IIA
You might be surprised........
My girlfriend loves the 101, once she figured out how to get in and out of it!
'00 Disco, a beast!
Old October 30th, 2015, 07:02 AM
johnny3rovers
John Holmes III
1965 Series IIA
Some additional views.........
I need to get those Strombergs out of the dining room!
Name:	chassis plate.jpg
ID:	133461   Click image for larger version
Name:	Exmoor Buckets.jpg
ID:	133463   Click image for larger version
Name:	RH plates.jpg
ID:	133465   Click image for larger version
'00 Disco, a beast!
Old October 30th, 2015, 07:12 AM
solarguy's Avatar
solarguy
Abraham Bell
1985 Defender 110 Tithonus
I love 101's. GLWTS!!
Old August 10th, 2016, 04:30 PM
johnny3rovers
John Holmes III
1965 Series IIA
Forward Control 101 GS
72FL64, Land Rover 101 GS 24V One Tonne 4X4
One of only 474 ever produced in this configuration. It is probably one of only 10-15 of any configuration in the US.
John Craddock, Ltd. used this vehicle in its company logo in 2015. It is soon to be featured in a segment on REV’N TV from an interview done – believe it or not – at a street rod show in May 2016. This 101 was featured in an article in the 101 Club magazine, Six Stud in the UK, May 2015.
Highlights:
The 101 is powered by 3.5L aluminum Rover V8, originally with twin Stromberg carbs. The engine was rated from the factory at 135bhp at 5,000 rpm and 205 lb/ft of torque at 3,000 rpm. Currently, the vehicle is fitted with a single Rochester 2Jet carb. Two sets of original Strombergs and two manifolds are included in the sale.
The 101 is full-time 4WD, with a vacuum locking center differential, parabolic springs and front sway bar. There are eight forward gears and two reverse. The heavy-duty Salisbury axles, front and rear, have larger half shafts than standard. The axles have a 5.57:1 ratio and this combined with the step down in low range gives an amazing 74:1 low range first gear, nearly twice as low as a standard Land Rover and allows only 7mph at 5,000rpm!
The ride is a bit harsh as you would expect, and the steering effort is high, but the handling is surprisingly good, with little body roll, thanks to the beefy front sway bar and parabolic springs.
With the exception of the Rochester carb, Mallory 12V electronic ignition, new Exmoor High Back seats, 3 point seat belts, new Exmoor Canvas hood and the odd clamps, wires and hoses, the vehicle is completely original. The original green canvas is included in the sale.
When the 24V alternator spools up, it sounds like a gas turbine, very cool! All military convoy lighting works as it should and the cargo bed sides and tailgate can be lowered and/or removed to reveal a flat cargo floor.
All records and receipts from my ownership and numerous spares are included in the sale. The e-parts book, repair manual and operation manual are included. Most ancillary parts are Series III and the 101 Club in the UK has an amazing number of hard to find, 101 only, parts as does John Craddock, Ltd.
The vehicle has been disassembled, stripped of all coats of military paint, both body and frame and the body has been repainted in original Land Rover Bronze Green. Recent new clutch, pressure plate and throw-out bearing. New brake master cylinder and servo.
Purchased from Ike Goss, Pangolin 4X4, Springfield, OR in early 2014, all refurbishment and maintenance since completed by Lance Christian, Eccentric Auto Works, Knoxville, TN. Lance has been working on my Land Rovers for twenty years.
This Land Rover gets looks and thumbs up at every traffic light, conversations at every gas pump, is the center of attention at every show, will go almost anywhere and could pull the foundation out from under a house!!!!
Numerous details:
• New Exmoor canvas hood.
• New Exmoor High back Bucket seats and 3 point harnesses.
• Dynamat heat and noise insulation around the engine compartment.
• Terrafirma rear differential guard.
• All new instruction plates throughout.
• New gauge cluster, oil press, oil temp, fuel.
• All vacuum hoses replaced with high quality German cloth braided hose.
• Various new camlocks, switches, relays and sending units.
• New batteries.
• Reproduction number plates 72FL64 from Tippers in the UK, made on the same press that produced the original stampings for the MOD.
• Refurbished front grille and Land Rover badging.
• One new and one restored door top.
• Military bridge plate. The 101 Club says this is a must have!
• NOS door check straps.
• New defroster hoses.
• NOS rear heater hose.
• New rear heater vents, not original, but they fit and work perfectly!
• Acquisition of an original six bolt spare wheel, probably the only one in the US!
• New shock absorber bushes.
• New sway bar and steering stabilizer bushes.
• New MOD marker, tail, turn and brake light lenses.
• New rear reflectors.
• Refurbished original wood pickaxe and shovel on bulkhead.
• New clutch, pressure plate and throw-out bearing.
• New brake master and servo.
• New brake and clutch fluid reservoirs.
• New door seals.
• Some stuff that I have forgotten…………
The vehicle is essentially done, but there a few minor things, cosmetically, left to do:
• Strip and repaint instrument panel and replace speedometer.
• Repaint heater box, crinkle finish.
• Repaint low range lever.
• Replace mud flaps.
The instrument panel would be the most tedious, because of the wiring, but only a one Saturday job. All the rest could be accomplished in one day, as well, but as with all Land Rovers, you need two people to remove the mounting bolts! One person on the outside and one on the inside!
One last thing that would make this the ultimate beast, visually, would be the replacement of the 9.00r16 bar grips with an 11.00r16 tire. Michelin XL would be my preference, but they are NLA. Coker Tire has a reproduction directional bar grip 10.50r16 that would be my second choice.
$32,000
John Holmes 865.382.7624 or PM
'00 Disco, a beast!
Old August 10th, 2016, 06:56 PM
solarguy's Avatar
solarguy
Abraham Bell
Nice truck. GLWTS !!!
Trade: NAS ST Grey Leather Forward Facing Bench for Grey Vinyl Forward Facing Bench KKilo23 For Sale - Parts 4 October 15th, 2013 12:24 PM
Forward Control NC Left Hand Drive Raleigh D90 The Flea Market 11 November 10th, 2010 04:49 PM
101 Forward Control and Series Sighting Grover Misc. Chit-Chat 4 November 12th, 2008 10:38 AM
101 Forward Control and built Jeep Wrangler Spectre For Sale - Vehicles 16 September 15th, 2007 07:01 PM
6x6 101 Forward Control gtg067i Misc. Chit-Chat 2 December 14th, 2005 08:55 PM
