'71 Series IIa - $6,500 - Defender Source
Old August 16th, 2009, 12:00 PM
Winston-Rover's Avatar
Winston-Rover
Mike Giovannozzi
95 D-90 ST
I'm moving to Seattle and need to sell my project Series IIa. It is in running condition but still needs more work. Includes lots of new parts - some installed, some not.
I'm asking $6,500. Located in Boynton Beach, FL.
Details:
Recently overhauled entire brake system (also have spare brake cylinders and pads), installed new rear crossmember, new parabolic springs and shocks, tune-up and new electronic ignition. All wiring checked and working
New Parts Installed
Alternator (Ford Conversion) & Belt
Rovers North Parabolic Springs & U-Bolts
ProComp Shocks
Replaced Rubber Brake Hoses
Brake Shoes
Brake Cylinders (Rebuilt)
Brake Master Cylinder (Rebuilt)
Rear Brake Line Brackets
Water Pump, Thermostat, Coolant & Heater Hoses, Radiator Cap
Brake Power Booster
Spin-on Oil Filter Adapter
Speedometer Cable (Needs New Speedometer)
Rebuilt Hubs (race seals), new front hub caps
Pertronix Ignition and Flamethrower Coil
Tune-up (new Distr. Cap/Rotor, Spark Plugs, Plug Wires)
K&N Air Filter (Also have original Oil Bath Filter)
Choke Cable & Choke Warning Light Switch
Brake Light Switch
Oil Pan Gasket
Rear Crossmember
Rear Mud Flaps (genuine)
Rear Bumperettes
Wipac Lights All Around
License Plate Light
Defender Style Parking Lights
Defender Style Side Mirrors and Door Hinges
Swing Away Spare Tire Mount
Ignition Switch
Used Parts
Rear Tailgate (I started to clean this up. Needs to be stripped and painted)
Spare Rochester Carb (needs rebuilt)
New Parts/Spares Not Installed
Complete Windshield Washer Assembly (reservoir, pump motor, jets)
Rear View Mirror
Water Temp Sensor
Back-up Light Switch
Retractable Seat Belts & Corner Brackets
Brake Rebuild Kit (including Brake Shoes, 4 Brake Cylinders, springs)
Front Floor Mats
Complete Wipac Light Set
Interior Dome Lamp
Wheel Arch Extensions (fiberglass)
2 Pair of Wiper Blades
Fuel pump rebuild kit
Clutch Master & Slave Cylinder rebuild Kits
Clutch Hose
Brake Master Cylinder Rebuild Kit
Spare Brake Pedal & Accelerator Springs
Steering Box Cover
Wipac Headlight Buckets
3 Pair of Tie Rod Ends & Clamps
2 Differential Seals
2 Steering Relay Oil Seals
2 Reverse Gate Springs
2 Propshaft Gaiters & Clamps
Brake, Clutch, Accelerator Pedal Pads
Gaiter for Gear Lever, Handbrake, Low Range Lever
Knobs for Gear Lever, Transfer Lever and Four Wheel Drive Lever
Coolant Reservoir Tank
Bronco Bikini Top & Rails
Rover Specific Tools
Lug Wrench
Starting Handle
Hub Nut Tool & Bar
Drain Plug Tool
additional photos can be seen at:
http://www2.snapfish.com/thumbnailsh...NAME=snapfish/
please email me at mgiovannozzi at gmail.com or call at 561-703-5230 for more details
ID:	21094   Click image for larger version
Old August 21st, 2009, 09:55 AM
Winston-Rover
Mike Giovannozzi
95 D-90 ST
So no one is interested?? I'm open to all offers. Make me an offer!!
Old August 21st, 2009, 01:37 PM
rovertrader's Avatar
rovertrader
Dale
$3500 if it has the title.
Old August 21st, 2009, 07:50 PM
GYM's Avatar
GYM
Gary
97 SW
Keep it. You'll need it for the crappy, pothole-strewn Seattle roads...
Old August 22nd, 2009, 02:32 AM
lecrobro
Levi Brown
02 Disco2
Smile dont be a dick
ouch...that bad?
'71 series deserves better respect than that.
easy to say that, not easy to say you'll care.
dick move.
just bought the '69 on here and gonna fix it up, give some honor to tradition and some honor to age...
i dont know how your parents taught you, but not very well, obiously, with all these oldies but goodies flying around- pick one up, make it your own, and love it till the day you die...
wtf
- levi
Old August 22nd, 2009, 07:00 AM
Bozman's Avatar
Bozman
Greg
1991 200tdi D90
That's your first post Levi?
Not a good start.
Old August 22nd, 2009, 07:44 AM
Originally Posted by lecrobro
ouch...that bad?
dick move.
wtf
- levi
? I don't even understand what you're saying - is selling it a "dick move" or is Rovertrader's offer a "dick move?" Typically people act like "dicks" towards other people, not towards cars...
Old August 22nd, 2009, 07:55 AM
kjva
Ken Jackson
1985 110 Wagon
Seems like the post belongs on the disco board or whatever it is called I went there once and some of the stuff was offensive pertaining to the MAR being held at Oak Ridge
Old August 22nd, 2009, 10:46 AM
Winston-Rover
Mike Giovannozzi
95 D-90 ST
I'm also puzzled. really not sure what he meant.
If no one is interested I'll ship it to Seattle and continue to work on it.
I have the title. it's registered in Florida. send me a pm if you're truly interested. not sure if we can make the deal fast enough though. I'm leaving on Thursday and will ship it out Tue or Wed if it doesn't sell.
Old August 22nd, 2009, 12:37 PM
GYM's Avatar
GYM
Gary
97 SW
If it comes to that, you won't regret it.
There are a number of good Series resources in the PNW; (as well as this Board.)
PM me when you get in to town if you'd like more info...
Old August 22nd, 2009, 02:10 PM
rovertrader
Dale
I am always serious- I believe others will attest to that. Not a problem timing wise. I am in Va Mon and Tues. May can come down Wed, as I have a D-II to get in Orlando, and could tow yours back behind it. PM sent w/ contact info. Or if you like, load it up w/ all the extras, and if you can get it over to Brit Rover they will hold it til I can get there. Always options.
I have no idea what the newbie means either, but like Greg said, quite a start....
Old August 22nd, 2009, 03:17 PM
draaronr's Avatar
draaronr
Here
LR3
the flat bed infront of it is a nice touch
Old August 22nd, 2009, 05:06 PM
Winston-Rover
Mike Giovannozzi
95 D-90 ST
Ha ha. I didn't catch that at first. I stored the rover for a year while working in Dubai. I the took the photos when it was being picked for storage.
Old August 25th, 2009, 11:28 AM
Winston-Rover
Mike Giovannozzi
95 D-90 ST
No Longer for Sale
No Longer for Sale.
Well guys, I told my wife that I plan on buying another Series Rover once we get to Seattle and she convinced me to just ship this one instead.
thanks for the offer Rovertrader.
Old August 25th, 2009, 11:35 AM
Bozman's Avatar
Bozman
Greg
1991 200tdi D90
I am going to need complete transcripts of that conversation for future reference. Be as detailed as possible, including the tone you used, and and gestures that you may have thrown in as well.
Seriously, that is great news. A small victory for all of us
Old August 25th, 2009, 12:43 PM
rover26c's Avatar
rover26c
Lee
1994 D90 ST
[QUOTE=Bozman]I am going to need complete transcripts of that conversation for future reference. Be as detailed as possible, including the tone you used, and and gestures that you may have thrown in as well.
Greg, very funny!
series
Series IIa, III 24V belts jhobbs For Sale - Parts 0 December 26th, 2009 12:02 PM
1967 Series IIa 95% rebuilt with Galvy chassis Dfndr90 For Sale - Vehicles 1 July 12th, 2007 01:27 PM
Series IIa short wheel base TDI Guy Wanted 3 August 12th, 2004 01:15 PM
Great looking Series IIA on EBay boshea Misc. Chit-Chat 3 April 24th, 2004 12:14 PM
