1995 SW 300 Tdi - Defender Source
Old July 26th, 2005, 05:48 PM
neo812's Avatar
neo812
Kris
1985 Tithonus
1995 SW 300 Tdi
1995 Land Rover Defender SW 300 Tdi. 49,000 miles 46,000 at time of rebuild
I am selling this truck because I want to buy a plane. It has been rebuilt from the ground up.
Every steel component on truck has been galvanized including roll bars. All doors are new. Every part of body has been sanded, acid etched, epoxy primered, and painted inside and out prior to assembly. Color is Sandglow
Engine is a 300 Tdi from Rovers Down South with 39,000 miles on it. Timing belt replaced at time of install.
R-380 5 Spd
LT-230 w/ Q gears
New parts are:
Bulkhead. Also galvanized
300 Tdi wiring harness
Radiator and intercooler
All hoses. Water, oil, and intercooler
Entire brake system including calipers
Center differential rebuilt
Bearings and seals in everything
All ball joints and tie rods
Every fastener and bolt in truck is new. Stainless everywhere except where critical. Used grade 10 metric for all suspension ECT.
All seals and gaskets on body and windows
Windshield
Rear A-link swivel
Bushings
Doors, door latches, locks, and hinges
Headliner recovered
All lights
Truck has Dynamat on entire interior
Genuine Land Rover Rubber (The thick stuff, not the cheap NAS stuff.)
Mechanical gauges (Water, Oil, and Voltmeter)
5-35X 12.50/15 Pro Comp X-terrains on American Racing Steel rims w/GCR cad lug nuts. Also included 2 315/75R 16 Pro Comp X-terrains w/ 60% tread left
All Air locker plumbing is in inner and outer tubing bulk headed thru body so it will never rub through. Regulator and extra air chuck mounted by Power tank.
Doors are ST half doors with military door tops.
Rear cross member has been completely rebuilt and is ? thick with gussets back to frame. It will not fold in like the factory setup.
I will include in sale:
All original doors with roll up windows
GBR 4.74 gears and ARB air lockers
New 300 TDi water pump
Parts List
? Safari Guard 3 ?link
? Safari Guard 3-link cross member
? Rovertym springs
? Rovertym Drop cones
? Rovertym rear shock mounts upper and lower
? Rovertym rear trailing arms
? Rovertym front shock mounts
? Fox Racing eye-eye shocks
? Poly bushes
? Rebel steering guard
? ARB winch bumper. Line-X ?ed
? Warn 9500 HS winch
? Aluminum gas tanks skid plate
? Shrockworks rock slider
? Mantec snorkel
? 6 Hella lights
? Limb Risers
? Safety Device roof rack
? Diamond plate Wing ,Bonnet ,and rear corners ? Black
? Tuffy center console
? The Source 10lb CO2 tank
? Aluminum rear door interior panel
? 48? Hi-lift jack mounted on rack
? Astrali steering wheel
? Pangaea stainless hood pins
? VDO Egt gauge
? Mechanical water, oil ,and volt gauge
? GBR 4.74 diffs w/ ARB air lockers. Currently running my 3.54?s in truck. Both come with truck
? Old Man Emu steering stabilizer
? GCR stainless door top bolt
? AB stainless Quick-nuts
? GCR pneumatic air locker switches
I cannot begin to tell you how nice this truck is. Think ECR just less money. I unfortunately haven?t had the chance to take it off-road yet. So it looks like a factory new truck underneath. I undoubtedly have forgotten some and will add it as I think of it.
I built this truck for myself and intended to keep it until it died. I have a new interest however and this can make that a reality.
I have pictures of the entire re-build for serious buyers.
Truck is $65,000.00
Please do not make any offers unless they are reasonable. I will not be selling this truck cheap.
E-mail me for my phone number if you would like to discuss the truck. Or would like specific pictures
ID:	3480   Click image for larger version
Old July 26th, 2005, 07:15 PM
sjreed
Stan Reed
Kris,
Just saw the truck. I would be very interested in seeing the complete restoration pictures. Please send to stanley.reed@frx.com.
Stan
Old July 26th, 2005, 07:18 PM
neo812's Avatar
neo812
Kris
1985 Tithonus
Also this is a NAS spec,not a grey market vehicle.
This is not a wrecked or salvage truck. Clean title. This is my personal truck and when I started putting my Tdi in I found rust on the bulkhead and wound up rebuilding the whole truck.
Old July 26th, 2005, 10:26 PM
AggieD90's Avatar
AggieD90
Kevin Collins
'95 AA Yellow & '97 Willow Green
Hey that looks like my roof rack...did you pick that up from a snot-nosed brat in The Woodlands off of a Diamond Plate edition?
Old July 26th, 2005, 11:07 PM
neo812's Avatar
neo812
Kris
1985 Tithonus
It is yours. My nephew is actually who bought it from you,then I bought it from him
Old July 27th, 2005, 01:07 PM
AggieD90's Avatar
AggieD90
Kevin Collins
LOL I thought I recognized that bent pipe on the floor section (funny story).
If you want some local advertisement we can put it on the Houston LR club website. Just email the web guy.
HLRC
Old July 31st, 2005, 04:55 PM
neo812's Avatar
neo812
Kris
1985 Tithonus
Link to pictures of rebuild and current picture of truck
Sorry, let me get it working right and I will post URL
Ok try this
http://www.dotphoto.com/go.asp?l=nas...DE&AID=2670320
It is still uploading so all should be up in a couple of hours
1995, 300 tdi, 95, tdi
1995, DEFENDER 90 300 Tdi $40,000 Firm MDS For Sale - Vehicles 1 April 22nd, 2006 05:03 PM
300 tdi lrnasd90 Wanted 2 July 29th, 2005 06:55 PM
MTL prices in Mass, 300 Tdi oil artm Defender Technical Discussions 4 September 10th, 2004 11:45 AM
