1970's Shorland MK 3 APC - Defender Source
Old December 20th, 2014, 06:35 PM
greenmountainrover's Avatar
greenmountainrover
Derek Chace
84 Lightweight FFR
1970' Shorland MK 3 APC $20k
I'm selling a super rare 100% orignal Shorland APC for a client. He also has a Alvis Saracen I'll be listing also. Runs and drives just needs paint sanded down and re spayed inside and out. Chassis is in good condition. It has a clean UT title and was imported in 1997. These drive way better and are a 100 times more usable then a Ferret. It will carry 3 comfortably and 4 for shot trips.m
My Shorland averaged about 10-12mpg and when running right would do 55-60. Weights in at 6,000lbs. I towed mine behind my 04 Range Rover with no problems. Pretty much everything is standered series's 3 so parts are very easy and cheap to find.
I sold mine in June for $24,000 that was not nearly this original and was missing all the stuff inside the turret.
Price is $20K also comes with a coupes grand worth of spare. Im working on a list
Give me a call any time
802-324-3370
Decodes as follows
942 Model: Land Rover, Series III
Body type: Basic
Wheel base: 109in
Engine: 6-cylinder
Model years: 1972-1979
Destination: Export, right-hand drive (RHD)
00156 Serial number
B Design: One significant design modification
Back
MK 3 backround info
The bulk of Mark 3 Shorlands were on Series III Land Rovers using a 2625 cc 6 cylinder petrol engine developing 91 bhp at 4100 rpm. The earlier marks of Shorland having been based on Series IIA Land Rovers had to have the headlights moved from the radiator area to the wings to comply with export lighting requirements. Besides the export market, the armour protection was compromised by accommodating the headlights into the radiator area and no doubt also reduced the efficiency of radiator cooling. This migration of headlights to the wings always gave a rather homemade appearance. However the early Mark 3 was still based on a Series IIA Land Rover, but as these were late Series IIA Land Rovers, they already had the headlights in the wings. The bulk of Mark 3 Shorlands were on Series III Land Rovers using a 2,625 cc 6-cylinder petrol engine developing 91 bhp at 4,100 rpm. But the Mark 2 was still in production, customers who wanted Shorlands for particularly arduous terrain were offered the Mark 3. Over 500 Mark 3 Shorlands have been Sold.
Green Mountain Rovers your Defender/Series sales and importation specialist.
802-655-4874
Old December 20th, 2014, 06:42 PM
greenmountainrover
Derek Chace
84 Lightweight FFR
Pics
802-655-4874
Old December 20th, 2014, 06:44 PM
greenmountainrover
Derek Chace
84 Lightweight FFR
More pics coming
802-655-4874
Old December 20th, 2014, 06:47 PM
greenmountainrover
Derek Chace
84 Lightweight FFR
Also forgot to add its fitted with the smoke launcher's which you cant bring into the country anymore so very cool. Also shows 15,000 miles.
ID:	109067   Click image for larger version
ID:	109069   Click image for larger version
802-655-4874
Old December 21st, 2014, 08:29 PM
greenmountainrover
Derek Chace
84 Lightweight FFR
client is open to offers
802-655-4874
Old December 23rd, 2014, 03:32 PM
greenmountainrover
Derek Chace
84 Lightweight FFR
Spares included
Shorland / Rover Spare Parts
Girling brake fluid – 4 qts
Filters – RTC 3183 - 2 units
Distributor Caps – 605544 – 2 units
Filter – JS 660 L – 1 unit
Wiper Blades – PRC 1330 – 2 units
Points and Condenser – RTC 3270 – 2 units
Head Gasket – 1 unit
Valve Cover gasket – 1 unit
Belts – RTC 3310 – 2 units
Electronic Ignition – 2 units
Rear Mirrors – 2 used units
Brake Master Cyl seals – 90606023 – 1 unit
Bearing Race – 599698 – 1 unit
Wheel Cyl Seal Kit – 275744 – 1 unit
Seal Kit – STC 500090 – 1 unit
Breather – 603330 – 1 unit
O-rings – 267828 – 5 units
Adaptor – 587666 – 1 unit
Carb rebuild kit – 606098 – 1 unit
Carb diaphragm kit – JS499L – 2 units
Starter solenoid – 13H 5952L – 2 units
Key/ignition switch – 551508 – 1 unit
F. brake kit – 600210 – 1 unit
Brass pipe adaptor – 624091 – 1 unit
Carb gasket kit – RTL1481 – 1 unit
Relay – 243972 – 1 unit
Carb Jet – 18 605827 – 1 unit
Headlights – 2 units, used
Shock/suspension bushing sets - complete , F & R – 2 sets
Ignition Coil – 1 unit
Ball Joint – RTC 5867 – 1 unit
Slave cyl – 2 units
Brake hose – 592374 – 1 unit
Brake hose – 59619 – 2 units
Brake hose – 551652 – 1 unit
Brake hose – 510823 – 1 unit
3-way union – BTB 657L – 1 unit
802-655-4874
Old December 25th, 2014, 10:49 AM
greenmountainrover
Derek Chace
84 Lightweight FFR
Im kind of amazed not a single comment. One of the rarest rover's out there and nothing. Client is open to offers. He is also willing to stripe and repaint inside and outside if needed.
802-655-4874
Old December 25th, 2014, 11:01 AM
Ray_G's Avatar
Ray_G
Ray Gerber
I'm guessing the armored car market is a pretty niche arena...you have to have a real want to ride around in a dumpster to appreciate. It's a fantastic vehicle mind you, and seems to be well sorted for the price. If it were an RSOV or WMIK I think folks would be a lot more vocal. GLWS!
Old December 25th, 2014, 12:38 PM
greenmountainrover
Derek Chace
84 Lightweight FFR
WMIK kits are stuff to find now adays...Its the little things like the ring mount that add up and cost more then the cage.
I like the Shorlands. I really miss mine but im eyeing up a Saracen in the UK right now as can carry the whole family.
802-655-4874
Old December 25th, 2014, 05:04 PM
Rugbier's Avatar
Rugbier
Gustavo
Not that is any of my business , BUT i have to ask what in hell are you going to do with a Saracen other than a Collector piece, however you said " will carry the whole family ?
Where? in the yard? I mean short of dropping the front Screen there is no way you can have that in a responsible fashion driving on a road.
BTW, bump for a nice APC
NO SIGNATURE
Old December 25th, 2014, 06:00 PM
greenmountainrover
Derek Chace
84 Lightweight FFR
I like to take the armor to the local airsoft field and hunt children. I figure a Sarcen will scare the shit out of them.
802-655-4874
Old December 26th, 2014, 06:32 PM
greenmountainrover
Derek Chace
84 Lightweight FFR
client says $16K with the spare, new tires, and can even get sanded down and painted inside and out for $4k is some one wants it done up like new.
802-655-4874
Old January 4th, 2015, 02:04 AM
greenmountainrover
Derek Chace
84 Lightweight FFR
still looking for a home
802-655-4874
Old January 10th, 2015, 10:17 AM
greenmountainrover
Derek Chace
84 Lightweight FFR
$15000
802-655-4874
WTS 1975 Shorland armored car. Pretty much a nicer version of a ferret greenmountainrover For Sale - Vehicles 29 July 15th, 2014 12:06 AM
I got a WWII APC gun turret for my series III, whats the best way to mount it? Neil McCauley Series Technical Discussions 50 July 10th, 2013 11:47 PM
Ava :: 1971 Land Rover (Shorland) MKIII greenmountainrover Defender & Series Truck Registry 0 June 24th, 2013 08:05 AM
Need Help With Buying A 1970 Series IIA - 88" Fender Seeker Series Technical Discussions 51 February 1st, 2007 02:48 PM
For Sale 1970 Series 11A/BCB V-8, 5-Speed talley-ho For Sale - Vehicles 4 May 2nd, 2006 09:53 PM
