Transfer case play - Defender Source
Go Back   Defender Source > Community Announcements & Support > Say Hello! New Member Intros.
Old June 28th, 2015, 07:50 PM
Low-Range
d. Stainton
1997 Defender 110pickup
Transfer case play
When under the defender I tied to see if there was u-joint play and found both front and rear driveshafts turn freely for an inch or so. What gives. By the way, I was following threads on brake issues and discovered whoever said check wheel bearings on the front was right on. Last mechanic left axle snap ring clip? off ,no spacer and one lock washer, where there should have been two, and that let both nuts back off. Thanks for help
transfer case
Nylock nut size, rear flange of transfer case - also identify T-case ratio hillstrubl Defender Technical Discussions 3 July 11th, 2012 02:42 PM
transfer case . . . transfer Abrooks Defender Technical Discussions 38 October 20th, 2008 09:04 AM
Transfer Case for sale vlocci For Sale - Parts 1 January 27th, 2004 02:36 PM
looking for a Transfer Case for '94 D90 rover_rich_d90 Wanted 5 November 12th, 2003 06:46 PM
How hard to replace a Transfer case? crash0577 Defender Technical Discussions 1 October 7th, 2003 08:40 AM
