newbie 90D owner cranking problems - Defender Source
Go Back   Defender Source > Community Announcements & Support > Say Hello! New Member Intros.
Old December 15th, 2014, 02:02 PM
ACBrown
Lori Brown
1997 Defender 90
Acquired 1997 Defender 90 and would like some advice. Replaced plugs and battery has been charged but upon starting it cranks but doesn't turn. I pulled a plug wire to check for spark but found none. Any suggestions?
Old December 15th, 2014, 02:10 PM
Brewie212's Avatar
Brewie212
Brian Kandefer
Also check fuel pump fuse
Old December 15th, 2014, 03:21 PM
ACBrown
Lori Brown
1997 Defender 90
new fuse put it
Replaced 15A fuse for the fuel pump. Still cranking but not catching.
Old December 15th, 2014, 04:18 PM
LuisC's Avatar
LuisC
Luis Constantin
98 Disvovery 1 LE
You stated you weren't getting spark from the plug wires. So that would rule out fuel pump.
You recently changed plugs and battery? Could you have missed reconnecting something? Or did you inadvertently snag and unplug something?
You also recently acquired this vehicle. Was it running before you acquired it.
If not, then I'm wondering about the coil or a sensor crank sensor.
Black Rhino Lives Matter
90, problems
Not cranking. bjp Defender Technical Discussions 11 December 24th, 2012 01:37 PM
Hand cranking a V8 ini88 Misc. Chit-Chat 3 July 25th, 2011 05:23 PM
Cranking/Running Problems Landy1 Defender Technical Discussions 8 May 2nd, 2009 02:48 PM
new sport for your 90d 1000kva Misc. Chit-Chat 0 June 2nd, 2007 08:48 PM
Newbie ST owner Cyborg Defender Technical Discussions 7 May 19th, 2004 02:11 AM
