need help - Defender Source
Go Back   Defender Source > Community Announcements & Support > Say Hello! New Member Intros.
Old February 16th, 2015, 11:14 AM
hans agterdenbos
hans agterdenbos
110 92
need help
Hi All,
I am located the last 8 years in Zanzibar Africa i want to buy a 110 but the VIN number give me problems do not know if its wise to buy this 110 the number SALLDHAF7JA911258 give a F for motor type means a
1.8L, inline 4 cylinder, 'K' Series, High Compression Leaded there is 319.000 on the clock there will be repairing soon. I can not find anything about this engine on google who can help.
Warm regards
Hans Agterdenbos
Old February 16th, 2015, 11:55 AM
jafir's Avatar
jafir
Jafir Elkurd
SAL Manufacturer code: Land Rover
LD Model: Defender (for early models: Ninety, or One Ten)
H Wheel base: 110 inch
A Body type: 2-door: Pickup, hood cab, truck cab, or soft/hard top
F Engine type: 2.5 litre Tdi diesel, model 11L (200Tdi) or model 16L (300Tdi)
7 Steering and transmission: Right-hand drive (RHD), 5-speed manual (LT85, LT77, LT77S, R380 or other)
J Model year: 1992
A Assembly location: Solihull, UK
911258 Serial number
Old February 20th, 2015, 08:35 AM
hans agterdenbos
hans agterdenbos
110 92
thanks i found more info
Hi
see this http://www.expeditiongear.co.za/cu5/...IN-Number.aspx
it seems a 1.8L, inline 4 cylinder, 'K' Series, High Compression Leaded I google but also will read this site also about that engine seems a problem child.
Warm regards,
Hans
Old February 20th, 2015, 08:41 AM
Originally Posted by hans agterdenbos View Post
Hi see this http://www.expeditiongear.co.za/cu5/...IN-Number.aspx it seems a 1.8L, inline 4 cylinder, 'K' Series, High Compression Leaded I google but also will read this site also about that engine seems a problem child. Warm regards, Hans
There are 2 engines associated with that code ... It's highly unlikely to be a K series engine unless it's been changed ... Why do you think it's that engine not a 200tdi??
Old February 20th, 2015, 09:14 AM
hans agterdenbos
hans agterdenbos
110 92
Hi see pict
see pict Click image for larger version
Need help with some dimensions.... tbmcneill Defender Technical Discussions 18 May 4th, 2004 04:14 PM
Need Some Help from Across the Pond DJ Menasco Defender Technical Discussions 2 April 28th, 2004 02:03 PM
need help to id a part Britt Easterly Misc. Chit-Chat 2 March 12th, 2004 12:17 PM
Need some HELP!!! Weldon Defender Technical Discussions 18 February 5th, 2004 11:35 PM
Need help with D90 engine problem Chris Cox Defender Technical Discussions 3 January 10th, 2004 08:41 PM
