More D90 Newbie ?'s - Defender Source
Go Back   Defender Source > Community Announcements & Support > Say Hello! New Member Intros.
Old June 26th, 2004, 04:24 PM
mlw911
Michael Walter
1995 D90 ST
More D90 Newbie ?'s
Hello all, 2 more simple questions.
1. I took off my roll cage to have some touch up work done. I put it all back together but have found I do not have or remember what screws go in the top of the rear hoop to hold the middle part on. The regular short black torx are too short. Any ideas?
2. Does anyone know the setup for the factory tire carrier where it attaches to the little bases on the car. Are there washers on the top and bottom of the swinging part, etc... I replaced my Safarigard tire carrier with the original and am not sure of the setup.
Thanks in advance, Michael.
Old June 28th, 2004, 09:41 PM
Question one I don't know but there are some on the board that just put there cage on that should.
#2 I can take a pic of mine it's a 94 ST if thats what you have to help as I'm not sure if I can explain what you are asking.
Old June 28th, 2004, 10:33 PM
flippedrover's Avatar
flippedrover
Tyler
'94 D-90
I looked at mine today and there are no washers that I can see on them. Just a lot of grease.
Jimmy Buffett
Old June 29th, 2004, 06:47 AM
mlw911
Michael Walter
1995 D90 ST
Hey guys. Thanks for the responses. I figured out Q#1. The previous owner had some sort of metal cylinder jammed into the holes for the rear cantrails (sp) where they connect into the rear hoop. It looks like they are designed for something. I just pulled them out and now the standard torx will fit. Alot of grease on Q#2 is all I am looking for.
Michael
90, d90
1997, D90 50,000 miles or less JMPDIV82 Defender Technical Discussions 8 October 25th, 2005 10:34 PM
D90 Tshirts norros Misc. Chit-Chat 16 March 8th, 2005 11:05 AM
Looking for a wrecked D90 or D90 frame & body mdb77 Defender Technical Discussions 17 January 11th, 2005 09:54 PM
94, AA Yellow D90 Zimbo76 For Sale - Vehicles 9 October 27th, 2004 10:39 AM
