Greatest morning ever! 97 NAS 90 - Defender Source
Go Back   Defender Source > Community Announcements & Support > Say Hello! New Member Intros.
Old March 17th, 2016, 11:34 AM
soccerlaw
Paul Hourigan
1997 NAS Defender 90
After years of waiting to buy one and then a few agonizing days for it to arrive, this morning I got my very big, and I'm sure very costly, bundle of joy!
I'm sure I'll be asking a fair amount of silly questions as I'm a complete novice when it comes to these cars, so I'll kick it off in style by asking - is the gap between the window and the seals on the roof off bc 1) the doors aren't aligned? 2.) the roof isn't attached correctly or 3.) this is just how it is on a defender and I should deal with it?
Absolutely cannot wait to enjoy this car and will take some pics later for the registry once I get it cleaned up.
Cheers!
Paul
ID:	145236   Click image for larger version
Name:	defender window.jpg
Old March 17th, 2016, 11:40 AM
RBBailey
RBBailey
1965 IIa
Congrats! More pics?
And to answer your three questions: Yes.
Project:
1965 IIa SWB
Old March 17th, 2016, 11:45 AM
waveridin1959's Avatar
waveridin1959
Brian Jones
1995 D-90 ST #2892
Question 3 - Since that's an original Bestop, be glad it A) is still intact and B) the gap isn't bigger.
Congrats.
1995 Defender ST
1996 Discovery SE7
2008 LR3 HSE - Wife's
Old March 17th, 2016, 11:57 AM
JohnsD90's Avatar
JohnsD90
74 SIII 88", 88 110, 91 110
Congrats.
That is a massive gap, even by rover standards.
Old March 17th, 2016, 12:09 PM
Congrats.
Regarding that gap, there are a few things likely at play here. First, you are missing the hardware inside that provides tension along that vertical portion of your soft top (behind the front door). Do you also have the 5-snap rails that go from the windshield to the roll cage in the middle of the truck (called B pillar) above the front doors?
Your door tops may require some shims to also pitch them inward a little, but your door alignment(s) (door bottoms) are likely fine.
That top should be fine for a while, so you may look at replacing it with a Badger Coachworks top - either used or by ordering new and waiting a bunch of months.
Old March 17th, 2016, 12:18 PM
rovertrader's Avatar
rovertrader
Dale
Best solution for Atlanta- remove the door tops and all the zippered windows for summer, and save up for a Badger for winter- or continue to run topless/windowless, which is my preference.
Welcome!! And congrats!!
Old March 17th, 2016, 12:19 PM
Here are the instructions for installing a soft top to your vehicle. The hardware I referenced above is mentioned on page 2 and called the vertical rod / rods and horizontal bars (with snaps).
http://www.defendersource.com/tech/d90top.pdf
(and my own personal instructions)
http://www.defendersource.com/forum/...top-55270.html
You can also look around in these areas for information you want to look for or become acquainted with, and have a look around the Defender Technical information section of the forum.
Technical Articles
D90 Source - FAQ
Custom Modifications
Defender technical discussions
Defender Technical Discussions - Defender Source
Old March 17th, 2016, 12:21 PM
D90Overkill's Avatar
D90Overkill
David Frank
1995 ST #2615
Congrats! A beauty!
In the pic, I can see that the forward window frame isn't running parallel to the windshield frame. What does the other side look like? So the gap in back is probably the same as the gap/angle up front. Is there something pushing it out up front? Gasket out of wack? Are the speed nuts tight? Anything under the window frame, like a shim, other than the gasket? How far was it transported, as those windows, if loose, can work themselves out by buffering at speed.
Old March 17th, 2016, 12:26 PM
JimC post on how to pitch your door tops inward.
http://www.defendersource.com/forum/...trol-7172.html
Old March 17th, 2016, 03:45 PM
soccerlaw
Paul Hourigan
Wow. Thanks everybody for the responses. I'm going to take a closer look using the links and info provided to see if I can figure out what is going on. In the meantime... I'm going to follow @rovertrader's advice!
Old March 17th, 2016, 05:10 PM
xplorUtah's Avatar
xplorUtah
Andrew P
1960 SII
That there represents one of the best (woohoo) and worst ($$$$) days of your life! 😀👍. Congrats!!
1960 Series II "Pliny"
1997 D90 SW #2496
"Fear profits man nothing"
1997 D90 SW #2139 Portofino Sold
1995 D90 ST #2445 Beluga Black Sold
1995 RRC SWB Beluga Black Sold
1986 110 200TDI "1 of 1" Sold
Old March 17th, 2016, 05:27 PM
1of40's Avatar
1of40
1of40
NAS 97SW & 83 One Ten Tdi
I bet if he keeps up with the basic maintenance, stays away from unnecessary add-ons and drives it often it'll be the best vehicle he's ever owned.
Old March 17th, 2016, 05:31 PM
rovertrader
Dale
X2!!
Old March 17th, 2016, 05:38 PM
Broncoduecer's Avatar
Broncoduecer
peter
D90
Sound advice! Congrats on the purchase.
Old March 18th, 2016, 12:24 PM
soccerlaw
Paul Hourigan
@1of40 - great advice! Although, I just ordered a badger top so already worried about my commitment to not buying things for this truck (that said, it seemed pretty important for my enjoyment of it).
Old March 18th, 2016, 12:28 PM
smob's Avatar
smob
Steve
'97 Arles Blue SW #2131
Get your oil cooler lines replaced if they're still the old-timey OEM rubber.
-Ren Ching
Old March 18th, 2016, 12:30 PM
cellulararrest's Avatar
cellulararrest
Chris Snyder
1994 D90 #614 | '07 L322 SC
You definitely won't regret that purchase. They're great tops!
Old March 18th, 2016, 12:51 PM
jperakis
James Perakis
94 ST
what are these unnecessary add ons you speak of?
------ Follow up post added March 18th, 2016 09:52 AM ------
this is the most important piece of advice in this thread.
Order these from Trail Head 4X4 today if your vehicle doesn't have them in place already.
remember two things...
Old March 18th, 2016, 12:54 PM
Well, you'll regret the purchase until it arrives - but then you'll love it!
Old March 18th, 2016, 01:15 PM
1of40's Avatar
1of40
1of40
[QUOTE="jperakis;724207"] what are these unnecessary add ons you speak of?
Maybe proper recovery equipment before new LED taillights and plasti-dipped boosts.
90, 97, nas
What Makes America The Greatest Country? LRNAD90 Misc. Chit-Chat 5 November 7th, 2014 09:09 AM
Whats the latest and greatest in the world of door hinges? Arcadeus Defender Technical Discussions 11 March 24th, 2013 01:38 PM
absolutely dead this morning... snosrfr Defender Technical Discussions 4 February 28th, 2010 06:06 PM
morning boys Chris V Misc. Chit-Chat 4 February 13th, 2006 10:55 AM
The Greatest Rover Shop Ever Buckon37s Misc. Chit-Chat 2 December 22nd, 2004 01:00 PM
