The Brute :: 1994 Land Rover Defender 90 - Defender Source
Go Back   Defender Source > Build-up's, Projects & Registry Profiles > Defender & Series Truck Registry
Thread Tools Search this Thread
The Brute
Vehicle Name The Brute
Year 1994
Make Land Rover
Model Defender 90
Color White
Packages NAS #324
1994 Land Rover Defender 90 1994 Land Rover Defender 90 1994 Land Rover Defender 90
History Originally an Arizona car for the majority of it's life, it explains the major absence of rust on the truck. Original owner used it as a back-country wheeling vehicle, and set it up as a lean, mean, off-roading machine.
Exterior
1994 Land Rover Defender 90 Exterior
Plenty of "character" :).
Interior
1994 Land Rover Defender 90 Interior
- Sweet 'Smith & Wesson Chemical Company' shotgun mount sits...well, in the shotgun seat.
- Tuffy lockbox
Wheel and Tire
1994 Land Rover Defender 90 Wheel and Tire
255/85-16 BF Goodrich KM2 tires on black Wolf Rims (recently changed from 265/75-16 Dunlop Mud Rover tires)
Under the Hood
1994 Land Rover Defender 90 Under the Hood
3.9L V8
"Mom always said I couldn't handle the V8"
Suspension
1994 Land Rover Defender 90 Suspension 1994 Land Rover Defender 90 Suspension 1994 Land Rover Defender 90 Suspension
Fronts: Bilstein shocks / 2" lift springs
Rears: In the back it's a home-brew setup with extended shock mounts and adjustable long travel shocks, and retainers on the bottom. Also there are some serious home-made dislocation cones as well…they cover more than 1/2 of the length of the spring - this is a huge help too with getting that full travel. It sounds like the wrath of God when they dislocate, which scares whatever passenger I have in the truck at the time, but does the trick and allows the axle to drop ridiculous lengths. A quote from my buddy:
"your truck makes this un-holy bang/clang/boing/pow noises, and you guys go 'oh, that’s ok'….it certainly doesn't SOUND ok - how do you know everything is ok? I'm pretty sure everything is not ok".
Other
SG front bumper w/ Warn 10000 winch
SG steering guard
SG tie-rod guard
SG front diff guard
SG Frame sliders
SG Rock sliders
ARB front & rear lockers
1.222 transfer case
R380 transmission
4.7 diff gearing
Old June 28th, 2013, 12:29 PM
Arcadeus's Avatar
Arcadeus
Mark Bichin
97 NAS Station Wagon LE
nice truck... are you running stock bushings with the rear links or do you have a something else there? lots of flex!
Old May 9th, 2014, 12:39 AM
rauth.rauth's Avatar
rauth.rauth
Daniel
1986 Defender 90
Beautiful truck!
1994, 90, defender 90, land rover defender
Search this Thread:
Advanced Search
