DRAB :: 1987 Land Rover MOD 110 - Defender Source
Go Back   Defender Source > Build-up's, Projects & Registry Profiles > Defender & Series Truck Registry
Thread Tools Search this Thread
DRAB
speedpin's Avatar
speedpin
Vehicle Name DRAB
Year 1987
Make Land Rover
Model MOD 110
Color Olive Drab
1987 Land Rover MOD 110 1987 Land Rover MOD 110 1987 Land Rover MOD 110
Exterior
MOD 3 Door
Truck Cab in Winter
Soft Top in Summer
Tith bonnet and wing 5 bar
Sliders
Rockware w/ 9500 winch
Interior
1987 Land Rover MOD 110 Interior 1987 Land Rover MOD 110 Interior 1987 Land Rover MOD 110 Interior
Exmoor Trim high back seats
Wheel and Tire
1987 Land Rover MOD 110 Wheel and Tire 1987 Land Rover MOD 110 Wheel and Tire 1987 Land Rover MOD 110 Wheel and Tire
Steel wheels
BFG KO2 235 85 16
Under the Hood
200tdi
Suspension
Stock MOD HD rear Springs
OME Front springs
Old January 13th, 2016, 01:04 PM
SaltyDog
Bryan Estell
1986 Defender 110 Tithonus
Rock Rails
I'm building up a Tithonus 110 right now that has jerry can doors but both the doors and the compartments themselves hang down into where the rock rails should replace the sill. How did you fit yours?
Bryan
Old January 13th, 2016, 01:20 PM
speedpin's Avatar
speedpin
Looking ;)
Hey brian.
Trim them to be flush with sill line. Use standard 110 sliders.
~ Semper Fidelis ~
Old January 13th, 2016, 01:32 PM
or search to find this.
http://www.defendersource.com/forum/...ers-60707.html
Old January 13th, 2016, 01:43 PM
SaltyDog
Bryan Estell
Rock Rails
Thanks guys. Adam, looks like your rig is in the other thread too. If you don't mind, could you post pictures of what the trim looks like with the jerry can doors open (compartment sill and inside of door)?
I really want to avoid a trim but it might come to that. I did see a guy in the UK that raised his compartments about an inch (after cutting the body) and then install Mantec sliders. Different approach but just as scary.
Thanks again!
Old January 13th, 2016, 02:07 PM
meatblanket's Avatar
meatblanket
Mike Simpson
1955 86 1986 ExMOD 110
Originally Posted by speedpin View Post
Hey brian.
After doing that, can you still stuff a jerry can in there? My experience has been that the sidelockers are very tight with a 20L NATO can before you go make the opening smaller.
If you could post some pictures of the bottom of the interior of the locker I'm sure that would be very helpful to some of us considering this.
Old January 13th, 2016, 02:09 PM
Wolf Fabrication's Avatar
Wolf Fabrication
Sterling Archer
'08 D3
You're trimming the door, not the actual compartment.
Semper Fi!
Old January 13th, 2016, 02:33 PM
speedpin's Avatar
speedpin
Looking ;)
Yup. No loss of function.
ID:	139354   Click image for larger version
ID:	139356   Click image for larger version
~ Semper Fidelis ~
Old January 13th, 2016, 02:40 PM
meatblanket
Mike Simpson
Thanks for the pics. So in addition to trimming the door, you also cut the bottom off the frame that surrounds the door. Anything else?
I can't see any impairment to function, except to the extent that the bottom part of the door frame might provide some rigidity.
Old January 13th, 2016, 02:45 PM
speedpin's Avatar
speedpin
Looking ;)
That is it. I've had two full cans in there with no distortion in the bottom edge.
~ Semper Fidelis ~
Old January 13th, 2016, 03:33 PM
SaltyDog
Bryan Estell
Rock Rails
Awesome, just the pics I needed. Thanks again, Adam. We might have to go forward with this kind of alteration versus finding a custom rock rail.
Thanks! I'll post some pics once it's refurbishment and de-militarization is done.
Old February 2nd, 2016, 01:23 AM
SaltyDog
Bryan Estell
North America Overland was able to shim the jerry can lockers up a bit (required removing one rib at the top), which then required only a minimum of trimming (maybe a quarter inch) to the locker bodies to bring them flush with the sill. The locker doors themselves will be trimmed but then re-folded to add strength and to look like factory. Pretty cool!
110, land rover, mod
Search this Thread:
Advanced Search
