Broken :: 2002 Land Rover Discovery II - Defender Source
Go Back   Defender Source > Build-up's, Projects & Registry Profiles > Defender & Series Truck Registry
Thread Tools Search this Thread
Broken
Z.G's Avatar
Z.G
Vehicle Name Broken
Year 2002
Make Land Rover
Model Discovery II
Color Chawton White
Packages No Sunroofs
History Arizona/Arkansas truck
Overpaid for it
Exterior
2002 Land Rover Discovery II Exterior 2002 Land Rover Discovery II Exterior 2002 Land Rover Discovery II Exterior
03/04 Front grille/headlight conversion
Voyager rack
4 Hella 4000s up top
Hella LED rear work lamp
Hi-lift Jack - 48" Sand
Safari Gard bumper with skid
Superwinch 9.5 TS
Marlow synthetic line
Factor55 hawse and Prolink
Hood blackout
Terrafirma rock sliders with tree bars
Terrafirma anodized fuel tank skid
Terrafirma front & rear wraparound diff guards
Greg davis rear bumper
Hard Labor Creek rear tire carrier
Interior
2002 Land Rover Discovery II Interior 2002 Land Rover Discovery II Interior
Perfect headliner
ARB HD Compressor in rear storage bin
2 custom switch panels
A few dash lights on
Wheel and Tire
2002 Land Rover Discovery II Wheel and Tire 2002 Land Rover Discovery II Wheel and Tire
255 85 R16 BFG Km2s for the summer
285 75 R16 GY Duratracs for the winter
Under the Hood
*Drivetrain
Top end rebuild at 150k
Newer t-case from 04 Disco
Ashcroft CDL conversion
4.11 GBR gears
Ashcroft air lockers front and rear
Rovers North HD front driveshaft
GBR double cardon rear driveshaft w/U-joint conversion
Ashcroft rear HD axle shafts
Ashcroft front HD shafts w/ Meyle boots
6" Paragon Stainless Brake lines
Suspension
2002 Land Rover Discovery II Suspension
4" RTE lift
Fox 11" remote resi factory series adjustable
Eibach shaft bumper stops
RN lower front shock adapters
Terrafirma skeleton shock towers
Terrafirma HD upper shock ring
Terrafirma front spring cones
Terrafirma HD retaining rear plates
RN rear lower cones
Rear ruffstuff panhard rod conversion
Front Terrafirma adjustable panhard
Front Terrafirma correct radius arms
Rovers North HD steering rods
RN poly extended bump stops
No rear sway bar
Slickrock Fab quick sway disconnects
cover, disco, discovery, land rover
Search this Thread:
Advanced Search
