ZF Transmission Refill Quantity - Defender Source
Old February 11th, 2005, 07:13 PM
48vphantom's Avatar
48vphantom
Jeff Hoien
1997 NAS D90
Red face ZF Transmission Refill Quantity
Question for the D90 owners on the ZF automatic. Typically what has been the refill quantity in the auto box after a drain and refill? I know the whole thing holds around 10 including the TC but what should it take on average just in a refill? thanks for the info!! jeff
Old February 14th, 2005, 12:53 AM
48vphantom's Avatar
48vphantom
Jeff Hoien
1997 NAS D90
Here's what i have found on my own..the trans holds 9.6 quarts(per the manual, including the tc). an average drain and refill is anywhere from 6.5 to 7 quarts. And, the fluid level is to be checked cold in neutral(after running the shifter through the gears) but it can be checked hot also...add 19mm or 3/4 inch to the high cold level.
also, getting the crossmember out was easier than i thought...took the jack out of my kid's pathfinder, turned on its side, a block of wood and a few turns, the crossmember falls out...
jeff
transmission
ZF Transmission Hesitation Shifting 1of40 Defender Technical Discussions 1 July 26th, 2005 11:41 AM
Rebuilt ZF auto Transmission mudrover For Sale - Parts 6 September 28th, 2004 02:45 PM
94 discovery automatice transmission capacity cgalpin Defender Technical Discussions 4 August 26th, 2004 10:57 AM
ZF HP 24 Transmission ron Wanted 14 March 2nd, 2004 11:17 AM
ZF Auto Transmission 1997 Disco 60k miles castlerock4x4 For Sale - Parts 5 February 27th, 2004 06:10 PM
