ZF transmission question - Defender Source
Old March 24th, 2010, 10:34 PM
phoenix37's Avatar
phoenix37
john
Are all of these the same? I just bought a 95 SWB RRC and it needs a new tranny. Can i get one out of any RRC or Disco?
Old March 24th, 2010, 10:35 PM
specops1526's Avatar
specops1526
Beluga '97 90
Another truck???
Originally Posted by rijosho
Beluga 97 D-90
Chawton 04 DII SE
Tangiers 04 DII G4
Old March 24th, 2010, 10:42 PM
phoenix37's Avatar
phoenix37
john
Shhhhh!
Old March 25th, 2010, 06:48 AM
junkyddog11's Avatar
junkyddog11
oil soaked filter
95 RRC 300tdi
the later model RRC or early disco are better (94-95)
Matt Browne
Old March 25th, 2010, 09:58 AM
phoenix37's Avatar
phoenix37
john
Thanks Matt. Can you tell me what you mean by better? Will later model Disco transmission fit? Seems like there are more of those around.
------ Follow up post added March 25th, 2010 07:07 AM ------
How about the early p38s? again seem like there are more of those around here.
Old March 25th, 2010, 06:40 PM
junkyddog11
oil soaked filter
95 RRC 300tdi
All DI will fit. You should make sure to get the torque converter and all the shims to the flex plate also. Use your flex plate.
The newer trans is updated and although the exact spec I can't remember.....it is much smoother and I'm pretty sure the torque converter was improved also.
Matt Browne
Old March 25th, 2010, 06:48 PM
phoenix37's Avatar
phoenix37
john
Thanks Matt... got one from a 95 D1 on its way... $145 bucks delivered with a 90 day warranty!
transmission
Need help with Transmission question. michael15 Defender Technical Discussions 7 February 8th, 2006 10:44 AM
'94 clutch and transmission question CDN38 Defender Technical Discussions 4 January 31st, 2006 01:32 PM
ZF4HP22 transmission question..... kiphartzell Defender Technical Discussions 9 December 28th, 2005 09:11 AM
ZF HP 24 Transmission ron Wanted 14 March 2nd, 2004 11:17 AM
ZF Auto Transmission 1997 Disco 60k miles castlerock4x4 For Sale - Parts 5 February 27th, 2004 06:10 PM
» Defender Registry
Perentie
oowa
D90
WeBeCinYa
Add your Defender
