ZF Transmission Hesitation Shifting - Defender Source
Old July 26th, 2005, 11:35 AM
1of40's Avatar
1of40
1of40
NAS 97SW & 83 One Ten Tdi
I've only owned this 97 for a couple of weeks, but DAMN this transmission is tough to get comfortable with.
I'm experiencing what seems like zero pick up and a ton of hesitation in shifting from dead start. What I've noticed is it does not shift until i've clipped 3K RPM. Does this sound normal or do I have a transmission issue I need to deal with?
The truck has less than 50K miles and the previous owner has had all services through 60K performed at Peabody LR in MA which i think is a decent shop. I've got every receipt and there has been no mention of transmission issues before; but then again the previous owner only drove 10-15 miles a day locally around town -which may be the problem.
I'm looking for any advice/opinions you guys might have.
Clay
Old July 26th, 2005, 11:41 AM
I don't know much about the autos but I think you may need to adjust the kick down cable, but I would also smell the fluid, if it smells burnt then you may have problems.
Check out the FAQ for more info http://www.defendersource.com/faq/Trans/TransAuto.html
transmission
97 D-90 Auto Transmission Shifting at Higher RPM parkcity4x4classic Defender Technical Discussions 7 October 30th, 2006 05:35 PM
ZF Transmission Refill Quantity 48vphantom Defender Technical Discussions 1 February 14th, 2005 12:53 AM
Rebuilt ZF auto Transmission mudrover For Sale - Parts 6 September 28th, 2004 02:45 PM
ZF HP 24 Transmission ron Wanted 14 March 2nd, 2004 11:17 AM
ZF Auto Transmission 1997 Disco 60k miles castlerock4x4 For Sale - Parts 5 February 27th, 2004 06:10 PM
