ZF trans temp? - Defender Source
Old May 17th, 2004, 09:34 AM
dmarchand's Avatar
dmarchand
David Marchand
'97 D90 SW Arles
ZF trans temp?
I'm looking to install a trans temp gauge for my ZF (prefer a VDO gauge). I no longer run the stock ECU wiring. I know the ECU had a trans temp light and was wondering where that is located (on the trans itself) and whether I could tap it for a VDO trans temp gauge.
Anyone have any experience with this?
Or do I need to run something in line to the trans cooler?
Old May 17th, 2004, 10:17 AM
Don't they sell adapters so you can stick the sensor into the fill plug? And there has to be some wires someplace, there are wires coming off my trans and T-case to for reverse and high low. They are up high by the shifter. Did you just think of this this morning I could have helped when I stopped by on Saturday.
Old May 17th, 2004, 10:45 AM
dmarchand's Avatar
dmarchand
David Marchand
'97 D90 SW Arles
Thanks Mike. Yeah, I thought of it Sunday after I left the shop. I was just sitting down making a list to make sure I covered all the necessary temps/gauges and such now that the ECM is out. And I realized the trans temp that the ECM monitors (well, their is a light behind the dash console), was not going to be monitored.
I've never seen the light go on except during start up, but I know I could use it as a better way to monitor the truck.
Thanks though. Had I thought of it while you were there, I would have put you to work....
Temp guage problem TDI Guy Defender Technical Discussions 24 June 28th, 2013 10:42 PM
Has anyone put a temp senor & gauge on a ZF tranny? Hammertime Defender Technical Discussions 0 July 29th, 2009 08:28 PM
3.9 V8, hp22 ZF trans., lt230 tcase (1.2), early Defender seats tommyd For Sale - Parts 9 February 11th, 2009 12:54 AM
Replacement Motor and Trans for 110 gearco Defender Technical Discussions 39 July 2nd, 2004 02:16 AM
water temp stabilizer switch david jenson Defender Technical Discussions 1 June 16th, 2004 08:50 PM
