ZF Automatic drivers side mount - Defender Source
Old December 6th, 2010, 02:21 PM
FlaD90's Avatar
FlaD90
Tom
1994 ST D90
Can someone tell me what Bracket/Mount is used on the drivers side transmission in the D90. In the process of converting to auto(4hp22)
Thanks in advance
Old December 6th, 2010, 02:45 PM
carlosz's Avatar
carlosz
Carlos
I dont have a picture of it but the brakett is similar to an H pattern about 4 incles long, it bolts directly to the trans on one side and the other to a hockey puch style mount like the ones used on the engine, which in turn mounts to the frame.
Old December 6th, 2010, 03:05 PM
pendy's Avatar
pendy
jim pendleton
89'd90
You can get one from a disco 1 I have a few of them around here. Do you have the part that bolts to the frame?
legend in my own mind
Old December 6th, 2010, 03:12 PM
FlaD90's Avatar
FlaD90
Tom
1994 ST D90
I actually dont have the part which bolts to the frame, so not sure what it looks like. The "H" pattern mentioned sounds right.
would a unit from a Disco 1 work(Bracket)?? maybe a photo would help..
Old December 6th, 2010, 03:48 PM
ipgregory's Avatar
ipgregory
Ian Gregory
'97 D90 ST #1008
Couple of pics of the bits for both sides.
Name:	Trans Mounts for Auto.jpg
ID:	33775   Click image for larger version
Name:	Trans Mounts for Auto II.jpg
Old December 6th, 2010, 03:55 PM
FlaD90's Avatar
FlaD90
Tom
1994 ST D90
WOW!!......A true gentleman...
Thanks Ian
Anyone know a source for the drivers side bracket?
Old December 6th, 2010, 06:57 PM
if it is the same as a disco I or RRC
roverguy.com or roverdude or paul grant or ....
mount
Drivers side door trouble UtahD90 Defender Technical Discussions 3 December 7th, 2008 12:50 PM
Are Defenders heavier on the drivers side? Buckon37s Defender Technical Discussions 22 May 23rd, 2008 06:53 PM
NAS drivers side fender steved90 Wanted 0 August 1st, 2005 04:52 PM
WTB: Driver's Side Side Step dzientek Wanted 0 November 8th, 2004 12:21 PM
Wanted: D-90 seat back trim cover/ driver's side side step dzientek Wanted 2 August 23rd, 2004 06:39 PM
» Defender Registry
Cash
gilby
MOD110
Mod110
Add your Defender
