ZF auto conversion - lots of questions - Defender Source
Old November 19th, 2017, 05:50 PM
Noyac40's Avatar
Noyac40
1985 D110
I am getting ready to take the plunge on a 4HP-22ZF auto / Borg Warner T-case swap in my 110. I should have done this along with the install of the new 3.9 this year but wanted to drive it a little more with the LT77 before making a decision. I don't do a lot of off-roading (mostly beach) so I am not too worried about ditching the LT230 either - I just want more highway comfort and there's a lot of slop in the current setup.
I think that I have all parts but want to know what else I may need.
I have ( all from 95 RRC):
Auto trans with torque converter
Flex plate
BW T-case
Trans linkage with shifter
T-case linkage with boot
Front half shaft
Rear driveshaft
Trans mounts
Brake pedal assembly (for wide pedal)
I will install new U-joints in shafts, new chain in T-case, etc. Is there anything else that I am missing? Any issues with using the NAS cross member currently installed?
There was a thread I can no longer find that described torque converter distance to avoid crushing the oil pump upon install - it varies by serial number? - anyone know what I am talking about here?
Finally, there are tons of pics in the auto conversion thread with pics of console solutions, does anyone have pics of the install of the trans?
As always, thanks in advance for any advice.
Old November 19th, 2017, 06:31 PM
Nomar's Avatar
Nomar
Jeff B
RR HNTR,RR LWB Tdi
I would strongly recommend keeping the LT230 and ditching the Borg-Warner in your scenario...
Rent my
Old November 19th, 2017, 06:40 PM
Noyac40's Avatar
Noyac40
1985 D110
Jeff, Thanks for the feedback. I was told that the Viscous Coupler in the Borg Warner allows faster highway speeds (not like I am setting speed records anyway) - Will the auto and 230 combo still do ok?
Old November 19th, 2017, 06:42 PM
phoenix37's Avatar
phoenix37
john
All these LS converted trucks are using the Lt230 and they hold up to a lot more speed/stress than your 3.9 will ever throw at it. Who told you that? so we can publicly shame them
Old November 19th, 2017, 06:59 PM
Noyac40's Avatar
Noyac40
1985 D110
Ha! Cant throw anyone under the bus but now re-thinking this. I think my LT230 has about 150K miles like the rest of the old drive train. So, any guess as to rebuild cost?
Old November 19th, 2017, 07:33 PM
I assume the problem is the gear ratio in your current LT230. You can change that or simple get one from a Discovery. In fact that is where you should get everything, the gearbox, shifters and so on.
Old November 19th, 2017, 07:34 PM
emphaticaly
------ Follow up post added November 19th, 2017 07:36 PM ------
Someone lied
Old November 19th, 2017, 07:48 PM
Noyac40's Avatar
Noyac40
1985 D110
Thanks guys, good advice here. Is it a big deal to have the automatic lockout added during a rebuild- or is it even necessary? Also what are the best highway gears, 1.2?
Old November 19th, 2017, 08:56 PM
Paul K's Avatar
Paul K
Paul Kennington
'85 Ninety V8 SW
Yes. That’s the ‘tallest’ geared stock option (the other options being 1:4 or 1:6, which are geared lower). There is also an aftermarked cover that increases the oil capacity. I’m not sure what the consensus is on that.
Current fleet: '85 Ninety 3.9 V8i Auto SW,'07 BMW 335Xi.
Old November 19th, 2017, 09:05 PM
Noyac40's Avatar
Noyac40
1985 D110
Definitely worth a look if I rebuild, thanks
Old November 19th, 2017, 09:22 PM
Chris B
72 + D1 drivetrain =?
Any BW box still around has to have far beyond its sell by date. The LT230 can usually be picked up used with 1.2 gearing for $250 or do used.
Old November 19th, 2017, 09:24 PM
Depends on your truck-and how you will use it. IE will you tow with it ? Tire height ?
How tall is your truck ? Roof rack ?
Most say lower rpm @ highway speed= better fuel economy. I have not found that to be true. Rover v8's seem to do well around 27-3000 rpm on high way. I have 4 v8's on the road @ present all with 1.2 tcases and 32 or 33 inch tires. They get better mileage running 70-75 than they do @ 60-65.
Will likely run a 1.4 in the one I'm putting together now on 33.25 tires for this reason. Should help with acceleration and towing as well.
Old November 19th, 2017, 09:54 PM
Noyac40's Avatar
Noyac40
1985 D110
Mostly summer use as its a 110 5 door soft top and if I tow its just across the street to drop the boat in, not towing any distance. I am running 285 75 16 bfg's. 1.2 is what I think I have but its entirely possible that its just tired and needs a rebuild.
Old November 19th, 2017, 09:59 PM
In defense of the borg warner, it is very smooth and quiet. Also has the fattest chain drive of any TC of its type so is super robust. The VC does not fail on all of them as some would make it seem.
That said, having the LT230 and the central diff lock will be far more desirable.
Old November 19th, 2017, 10:01 PM
Put it together with what you have and see if you like it. Pre 1996 lt230's need to be updated with a crossdrilled input gear. I swap them all out for 1996 or newer Q (quiet) suffix boxes.Transfer cases are easy to swap out if you want to switch to 1.4.
Old November 19th, 2017, 10:14 PM
Noyac40's Avatar
Noyac40
1985 D110
Thanks for that. Its true, my 97 D1 was quiet and smooth, maybe that's the answer.
Old December 13th, 2017, 07:50 PM
Noyac40's Avatar
Noyac40
1985 D110
Resurrecting this thread since I have done some homework based on all of the great advice from the forum members, as usual - much appreciated! I will keep the LT230T transfer case but am questioning what to do. My options are:
1- Find a "Q" suffix TC from a 96 or later Disco (as Uncle Douglas mentioned) which, according to the following site will require a couple of M8 holes to allow for the handbrake need to be drilled into the casing.
LT230: The best ever transfer box? | Auto Express
OR
2- Rebuild my case, if possible, to upgrade to a cross drilled input gear and upgrade to gears that were used in the "Q" T-cases - if that's possible. Any idea on cost for this option?
I cant find my serial number either to see what I actually have since it is not below the PTO plate, any other place to look?
Old December 13th, 2017, 08:00 PM
It takes me maybe 20 mins to drill and tap the 4 holes
You will also want to swap over your speedometer drive gear and cable clamp.
There is a forum member parting out a d1 right near you @ Tappan Zee
Old December 13th, 2017, 08:07 PM
Noyac40's Avatar
Noyac40
1985 D110
Thanks UD, that's where I got the ZF and the BW TC. I will see if its a Q suffix, John is a pleasure to deal with.
Old December 28th, 2017, 06:12 PM
Noyac40's Avatar
Noyac40
1985 D110
LT230 Q identification
I am still getting all of my parts together for the auto swap and there is an auto dismantler nearby who has a transfer case from a 98 D1 which, based on the other threads, I assume must be a Q suffix case since its post 97 mid year? I called the guy and he sent me pics of everything but the actual serial number. Before I spend time going over there to look, is there a way to ID this Tcase from the pics attached?
ID:	340593   Click image for larger version
ID:	340609   Click image for larger version
ID:	340625   Click image for larger version
conversion
ZF Auto / Automatic Conversion - Let's see pics rijosho Defender Technical Discussions 122 October 4th, 2017 10:05 PM
Defender auto conversion parts Grade A pendy For Sale - Parts 8 February 18th, 2014 01:35 PM
Complete Auto Trans Conversion Kit themaxx Wanted 11 August 14th, 2013 12:01 AM
Manual To Auto Conversion willtillery Defender Technical Discussions 2 September 22nd, 2004 10:12 PM
ZF Auto Transmission 1997 Disco 60k miles castlerock4x4 For Sale - Parts 5 February 27th, 2004 06:10 PM
