zf auto and 1.667 transfer case - Defender Source
Old August 4th, 2009, 10:48 AM
Gibson04
Justin Church
1994 D90 / '04 Disco
I am running 33 inch tires with a zf auto and a 1.667 transfer case. When on the Highway I am running approx 62.5 mph at 3000 rpms.
Is anyone running 35's or 37's with this setup? I am tryingto get an idea of what to expect (speed vs. RPM's) when upgrading tire sizes. Ive tried entering in all the gear ratio's on couple different sites to calculate this info and dont feel it is entirely accurate.
I am going to buy some tires for my 90 and want to be in the in the 2600 - 2800 rpm range at 72 mph seeing that I drive this truck to and from the trails.
Justin
Here's the numbers Im putting into the calculator.
Zf has 4 forward gears. 1st gear = 2.73:1, 2nd = 1.56:1, 3rd = 1:1, 4th = 0.73:1. Im running 1.667:1 (high range) transfer case and 3.54 gears in the rear ends.
Are the Zf numbers correct?
Old August 5th, 2009, 06:34 PM
Hammertime's Avatar
Hammertime
Dana Hammersley
1997 Arles Blue #162
ratios
I put 4:11 Gears in mine and love it. At 70 mph it tacks 27-2800 rpm with 33's on it though.
Old August 5th, 2009, 06:36 PM
http://www.grimmjeeper.com/gears.html
Old August 5th, 2009, 08:08 PM
http://members.shaw.ca/red90/gears.html#zf4
transfer case
