Zf 4HP22 Transmission Governor Valve - Page 2 - Defender Source
Old March 15th, 2016, 06:49 PM
Viton's Avatar
Viton
Deaf Ember
Smart 4x4
I understand what you are saying. I have ran mine and shut off the engine while in gear many times & coasted into my garage while still in Drive, no issues. It may be the bolt on the output shaft of the Zf has loosened-up. The bolt is accessible by removing the cover off the rear of the LT230 (where you would hookup a PTO or overdrive) but I'm pretty sure the gear-set (part of the transfer case) that's in there has to be removed too to see it & get a socket on it to check the bolt's tightness. The gear-set should slide or screw right out into your hand.
transmission
ZF 4HP22 Transmission phoenix37 Wanted 5 March 25th, 2010 11:53 AM
ZF Transmission Hesitation Shifting 1of40 Defender Technical Discussions 1 July 26th, 2005 11:41 AM
ZF Transmission Refill Quantity 48vphantom Defender Technical Discussions 1 February 14th, 2005 12:53 AM
ZF HP 24 Transmission ron Wanted 14 March 2nd, 2004 11:17 AM
ZF Auto Transmission 1997 Disco 60k miles castlerock4x4 For Sale - Parts 5 February 27th, 2004 06:10 PM
