YRM door channel replacements - Defender Source
Old December 15th, 2013, 11:23 AM
lordhelemt's Avatar
lordhelemt
Paul
1995 D90 #2620 & NAS 110
Has anyone used the YRM replacement door channels?
I keep burning through the material when trying to join 2 pieces together. I've tried using both 6012 and 6013 rods with the amps turned way down. It either burns through when striking an arch or 1/2 way though my bead.
Has anyone stick welded these together and if so what rods/amps are you using? I can go TIG but i'm way more proficient at stick.
RIP 1994 D90 #999 (engine fire 2002). We'll miss you.
Old December 15th, 2013, 12:07 PM
revtor's Avatar
revtor
Steve Maietta
1969 IIA 88" Bugeye
Electrode negative will be better for thin metal like this. Check your setup. Also (obviously?) you need thinner rods for thin metal like this, or by the time your rod is up to temp, the puddle will have blown through..
1/16" 6013, 30 amps, electrode negative. start there.
Get some scrap metal of the same thickness to practice on! (18/20 ga)
I havent yet began tackling my doors/bulkhead but I will be looking for a MIG or using TIG for this thin sheetmetal. Perhaps practice a bit with your TIG setup, you will probably have better overall results.
~Steve
Old December 15th, 2013, 12:24 PM
lordhelemt's Avatar
lordhelemt
Paul
Thanks. I'm using 5/64" rods. I'll try electrode neg and 1/16" rods.
Old December 15th, 2013, 01:12 PM
The Dro
Dro
1988 Ninety
Do you know how to gas weld?
I've been doing it for a few months now and I like the out come.
You'll need to get the aviation torch body with a 0 or 00 torch tip.
Old December 15th, 2013, 01:24 PM
lordhelemt's Avatar
lordhelemt
Paul
I've done some tig but I need to work on my cups. I'll go that route if 1/16 and reverse polarity doesn't work.
Old December 15th, 2013, 07:03 PM
The Dro
Dro
1988 Ninety
I'm no expert...
But I've been practicing on 18 Gauge sheet metal and I like gas welding.
I dont don't remember the rod size. I can get that tomorrow night. I'll be in the shop where I'm getting my welding time.
Old December 15th, 2013, 07:43 PM
I have used the stock with a mig but not stick welder. I use my lincoln stick welder on thicker stock where I want deeper penetration. Sheet metal= mig/tig welders
Old December 15th, 2013, 10:58 PM
RobTheGob's Avatar
RobTheGob
Rob
1963 IIa 88 & 1995 NAS D-90 SW
I would have thought MIG would work well - and spot weld in several places.
How much material did they send? These door repair sections never seem to include the length of material that is included.
I'm curious how you make out - good luck!
Old December 23rd, 2013, 06:59 PM
lordhelemt's Avatar
lordhelemt
Paul
1 more to go
ID:	86616   Click image for larger version
Old January 2nd, 2014, 04:36 PM
RobTheGob's Avatar
RobTheGob
Rob
Is the amount of material they send for "one door" - enough to fully repair one door? I was thinking about buying three orders to do my two front doors. And perhaps two to do my SW rear door.
After seeing your original post - I spent some time practicing multiple tack welds (with GMAW) on very thin material and was happy with the results.
How easy was it to pull the door skin off? I should put an order in repair sections - might be a good spring project.
Old January 2nd, 2014, 06:06 PM
lordhelemt's Avatar
lordhelemt
Paul
1 kit was enough to do the bottom and 1/2+ up both sides.
Surprisingly the skin removal was pretty easy.
ac, channel, door
Hose replacements kolvedic Defender Technical Discussions 1 March 14th, 2006 04:50 PM
OEM Antenna or Replacements boshea Defender Technical Discussions 14 January 18th, 2006 01:15 PM
LED replacements: class 101 input discussion pls paulb Misc. Chit-Chat 7 March 18th, 2005 05:15 PM
Exact replacements for OEM speakers Kimos Defender Technical Discussions 6 December 21st, 2004 12:46 PM
Door hinge screw replacements - guidance paulb Defender Technical Discussions 4 September 22nd, 2004 06:51 AM
» Defender Registry
Lola
Alice
roberthoyt
Add your Defender
