york compressor - Page 2 - Defender Source
Old June 11th, 2015, 02:29 PM
LR Max
Thomason, Max
1973 Series 3 109
There is a bracket made for TJs and pulleys and crap. So that might be a good kit to look at/scavenge parts from or ideas.
My roommate in college had one mounted in his jeep. Always seemed like it never ran or worked. For the amount of money he spent on it, he could've gotten an electric compressor or C02 tank that just worked. Also it was kinda sketchy having the engine running while using the impact to tear apart the front axle.
Old June 11th, 2015, 03:21 PM
sad_story's Avatar
sad_story
andre
95' D90
I know Mike Slade is running dual Sandens in his Crew Cab. Ill see if i can get a pic from him to show location etc.
-Jeff
Sorry Jeff I wasn't very clear referring to the dual compressors
Old June 11th, 2015, 10:02 PM
Corsa
Shawn
1991 Defender 90
15 or so years ago I built a a York onboard air system for a Jeep I had at the time. The Jeep had a serpentine belt but I found the easiest way to drive it was to use a second V belt off the alternator. I took the serpentine pulley off the alternator and found a small V belt pulley that fit really good against it at a wrecker. I had a machine shop weld it up dead center and balance it. I built the compressor mount so the compressor and drive pulleys lined up correctly. You'll also need to construct it so the mount has a belt tension adjustment. I made slots for the mounting bolts. This was a bit of work to make it fit real nice and not look like crap. Now I would probably just buy a kit if one was out there.
This company is a great source for parts to make your own setup. Forget that they are made for Jeeps. The Jeeps in the 90's were using Sanden compressors I would almost think one of these kits would be a good starting point. I don't have AC now so I have no idea on the location of the AC compressor in a Defender so I might be wasting your time. Take a look at the mounting instructions.
::Kilby Enterprises::
Old June 11th, 2015, 11:58 PM
chris snell's Avatar
chris snell
Chris Snell
87 Ex-MOD 110
Gotta get a York so I can get an Amish air-powered blender for the trail.
1987 Ex-MOD 110 Tithonus LHD
2013 LR4
compressor
ARB Compressor Problem : Need HELP Jay Defender Technical Discussions 5 December 5th, 2005 09:52 AM
A/C compressor is whinning Campbell Defender Technical Discussions 7 April 1st, 2004 03:59 PM
On board air compressor Davis Defender Technical Discussions 5 March 7th, 2004 08:28 PM
Land Rover G4 Challenge - New York City, New York USA chrisvonc Trip & Trail Reports 0 February 4th, 2004 03:40 PM
AC to Air compressor Mike Hippert Defender Technical Discussions 5 October 25th, 2003 10:18 AM
