Yet another stalling thread..just looking for some advice - Defender Source
Old August 16th, 2014, 01:07 AM
El Solis's Avatar
El Solis
Chris Solis
Camel Trophy 110 sorta :)
OK so just took an amazing 5 day trip through the Sierras, truck ran so well it was scary (new timing belt, advanced timing, etc thanks everyone, total of more than 500 miles without issue until the end). On the way home for some idiotic reason I drove the thing until the diesel light came on. Stopped, fueled up while running (lil man was asleep and I needed the AC running). 35-40 miles later while going down hill (made it up a big hill no issues) the whole car shudders like it hit a huge invisible wall for a brief second then back to normal. this happens a few more times and I realize that the engine is momentarily stalling but then compression starting itself. I think to myself…must have gotten some sediment from the tank in the system from running it down so low. So I do the following steps:
200TDI defender version
1. drain sedimenter
2. replace fuel filter (filled with injector cleaner and diesel prior to installing)
3. crank over truck to confirm lifter pump is working (and it is)
4. crack the nuts at the injectors and crank over the truck, see diesel spraying in sequence from each injector pipe
5. HAVEN'T DONE THIS YET: remove injectors and clean
So my questions are:
1. am I missing anything?
2. If an injector was plugged why would it run normally for random amounts of time before stalling?
3. best way to clean the injectors?
Thanks in advance.
Old August 16th, 2014, 01:23 AM
Could you have sucked some air in the lines? How low did the fuel get? There's a bleeder screw on the fuel filter housing, crack it while running and see if any air comes out.
Old August 16th, 2014, 01:29 AM
El Solis's Avatar
El Solis
Chris Solis
I suppose air could have gotten in. I used the lift pump with the bleeder screw on the filter open to get rid of the air. Also cranked it over for awhile with the injector pipe nuts loose. I'll try cranking with the bleeder screw open tomorrow. As for how low I put in 19.5 US gallons. Pretty sure it's only a 20gal tank. It is whatever is standard on a row110
Old August 16th, 2014, 01:44 AM
I've had some pain-in-the-arse issues before getting all the air out...it was lumpy, or would run fine and then when I'd throttle up and back off it would bog down and then stall out at times. Bleeding the hell out of it, then a nice long drive sorted it out. Start with the easy stuff before you go throwing money or parts at it.
Old August 16th, 2014, 03:43 AM
there is a small mesh filter at the end of the fuel pickup line in the tank itself.
if there is any junk in the tank, that will clog up first way before the fuel filter ever does.
Old August 16th, 2014, 06:42 AM
NPT90's Avatar
NPT90
JT
D90 óriginalé
I had this happen to me in upstate NY in January... I was driving a vw tdi and I stopped at a truck stop to fill up.
As I was driving away my car started crawling and stalling, limped off the highway. Luckily I knew what the problem was... Bad diesel! More than likely your truck got some watered down diesel fuel (usually there is an acceptable amount of water in any underground fuel storage tank) sometime you show up right after they've done a delivery, sometimes they are running low and you get watery fuel.
I added some isoheat (2x bottles) and topped it off with diesel from another station. Car ran fine after.
I would suggest getting some fuel additive or draining it. I would def consider the fuel based on the scenario you're describing.
Why the hell am I awake
Old August 20th, 2014, 11:47 PM
El Solis's Avatar
El Solis
Chris Solis
OK update time: drained some diesel, added some water treatment and put back some known good diesel. so far so good but no long drives. Thank you everyone!!
Old August 21st, 2014, 07:54 AM
NPT90's Avatar
NPT90
JT
D90 óriginalé
back when I had my truck I used to keep additive in the truck for just such occasions. Its definitely magnified when you run the tank low (usually the remaining fuel in the tank can offset some of the watery fuel). Glad you got your truck fired up
Old August 21st, 2014, 09:23 AM
rdavisinva's Avatar
rdavisinva
Robert Davis
N/A
When you drained the sedimenter did an unusually high amount of water come out?
It sounds very much like you were passing air or water through the injectors.
As long as you have good fuel and the tank pickup and fuel lines are not clogged, you should be OK.
Now for the "repetitive broken record" for those of you old enough to remember vinyl, if you install a 12V pump after the sedimenter near the tank, wired to work when the key is switched on, it will provide you with a self bleeding fuel system
RDavisinVA
Old August 27th, 2014, 10:25 PM
El Solis's Avatar
El Solis
Chris Solis
And I'm back. To answer the last questions: I did not really notice a lot of water out of the sedimenter.
I have replaced a total of 12 gallons of good diesel and went for a drive today, still had stalling issues. engine just stops while cruising along and then will restart with a little blip of the throttle or pushing in the clutch. no problems with power, engine temps, EGTs, etc. everything is perfect except this little issue. happens at all revs/gears etc. I have just done the timing belt (but drove 800 miles including off roading without issues).
So, thoughts? Lift pump? clogged injectors? something else?
Thanks in advance.
Old August 28th, 2014, 05:24 PM
El Solis's Avatar
El Solis
Chris Solis
Bumpity bump
Old August 29th, 2014, 12:18 PM
crown14's Avatar
crown14
Verticalscrote
Volkswagen Super Beetle
Several times I have seen where people had previously pulled the sending unit from the tank, and resealed it with RTV. The fuel/vapors degrade the RTV, it falls in the tank, and under very low fuel conditions, gets sucked into this screen- or worse, someone has removed the screen and it gets sucked through the line. Worse yet, I once saw where someone removed the screen, then replaced it, making for lots of fun. The whole line was filled with little silicone "snakes" all the way to the filter.
Old August 30th, 2014, 08:59 PM
I would have said water in the fuel. I had a similar experience @ night in a rural area after all the stations had closed. In the mountains. I barely made it up a few hills. I stopped and drained water off a half dozen times. Took me an hour to go 25 miles. It gradually got better and I finally made it to a place that sold a product called HEET for diesel fuel and that helped but in the end I had to burn that tank through to get rid of the problem completely.
My tank didn't have a bottom drain or I would have dumped the tank.
Old August 30th, 2014, 11:07 PM
El Solis's Avatar
El Solis
Chris Solis
Crown you are just telling me ghost stories to scare me (it worked).
Doug, I have used the redline version of the heet for diesel as that is what the local shop carries. I have a feeling i just need to keep driving and adding good diesel. The hard part is not wanting to go on too far of a drive in case it just stops. Although the other day that happened, wouldn't start so i used the lift pump and i was back in business. I guess i just need to keep driving and draining.
Old August 30th, 2014, 11:25 PM
screen ? Most of the diesel defender fuel sender/pick up tubes I have pulled have no screen on the end of the tube
Old August 31st, 2014, 12:00 AM
NPT90's Avatar
NPT90
JT
D90 óriginalé
This actually makes a lot if sense, can't have suction if you're sucking atmosphere
Old September 8th, 2014, 11:13 PM
El Solis's Avatar
El Solis
Chris Solis
OK so new updates…I had another couple of episodes where the car just stopped. Dash light came on and power steering went out. This has happened 3 times and wouldn't restart. the other times it was a sudden loss of throttle/power with immediate return (either blip of the throttle or clutch in/out). When it just stops I have primed the lifter pump, air came out of the fuel filter and the last time no fuel out of the injectors (cracked open) on turn over. I opened the banjo bolt on the FIP from the fuel filter (Thanks to Shayne for the call a friend) and as soon as it was opened it was like it was pressurized as diesel sprayed everywhere like it was under pressure. So after this she fired up life was good. get home and decide I need to take this on actively (not just pour stuff in the tank). So as I am checking the wire for the stop solenoid i realize that it is in horrible condition. exposed frayed/cut wires at the female connector and when I touched the connector it fell off the wire. So I have redone the connector and drove today for 30 minutes without any issues. I'm not claiming victory yet but hopefully this was the issue and it is now fixed.
Old September 8th, 2014, 11:16 PM
Lucas... It had to be Lucas.
Old September 19th, 2014, 12:35 AM
El Solis's Avatar
El Solis
Chris Solis
Ok to close this chapter of awesomeness, 3 hours of driving, no stalling, i'm gonna say it was the wire to the stop solenoid. Thanks everyone!!
Oh and we added to the stable
I'm sure she will bring me the same joy as my 110 in time.
advice
OK, Yet another Intermittent Dying-at-the-Light Thread UTRPh Defender Technical Discussions 55 July 18th, 2014 05:30 PM
Yet another Engel thread steinhnj Misc. Chit-Chat 6 June 1st, 2014 08:38 AM
Stalling, stalling and more stalling !!!!!!!! DucatiChick Defender Technical Discussions 11 October 8th, 2012 04:59 PM
Yet Another overheating thread Defender90_218 Defender Technical Discussions 5 August 9th, 2010 09:24 PM
YANST (Yet Another No Start Thread) - fuel pump circuit issues cgalpin Defender Technical Discussions 25 August 2nd, 2009 11:23 PM
