Yet another snorkel question - Defender Source
Old June 30th, 2005, 02:50 PM
gtg067i's Avatar
gtg067i
Christian Shea
1997 Defender 90 Wagon
I really would like to build my own but stumbled across this unit....
http://www.paddockspares.com/shop/pa...pad703_400.jpg
I was thinking you might just be able to mount it drivers side and the bottom plenum would just be backwards which I think would look fine. I poked around under the hood and it seems like it might work, just not totally sure. Was wondering if anyone has done something similar. I just cannot justify 400 or so on a snorkel but this unit would set me back almost 1/3 of that price. Thanks in advance.
I require your largest, cheapest, most alcoholic brewed beverage.
Old June 30th, 2005, 03:29 PM
DaveHuny's Avatar
DaveHuny
Van Der Waal
none
That's for the diesel - the air intake is in the side of the fender. There's probably no reason you couldn't extend the hose to the side. There are lots of snorkel posts to read already, however.
Old June 30th, 2005, 03:57 PM
D90user's Avatar
D90user
steve
109/110 ambulance-55 series I
Just a thought but might the heater get in the way?
Old June 30th, 2005, 04:14 PM
jimmy salmon's Avatar
jimmy salmon
jimmy salmon
94 D90 AA Yellow
its a right hand drive the heater is the other side.diesel and gas have the air intake in the fender on UK models
3rd low and BOOT IT
Old June 30th, 2005, 05:04 PM
Davis's Avatar
Davis
Chris Davis
94 NAS D90 6.2LS
Yes, the heater on the NAS will get in the way of this. They do make the snorkel for the left hand drive, which you would want, and you could adapt a diesl fender mounted air filter--I looked into that, but found it to be too much hassle/expense (doing it with the air element). What you would need, in addition to the snorkel, is to fashion a 3" adaptor plate for the back side of the snorkel attachment for the inside of the fender--you will probably need to remove the fender to do this.
Best of luck on your project---
snorkel
Snorkel Question (Pic attached) Wolf Fabrication Defender Technical Discussions 24 December 27th, 2007 04:59 PM
snorkel question GeoParth Defender Technical Discussions 5 August 9th, 2005 07:53 PM
Mantec Snorkel Install Question ronward Defender Technical Discussions 2 April 1st, 2005 08:16 AM
Snorkel question searched and came up empty rustydefender Defender Technical Discussions 12 October 30th, 2004 05:43 AM
snorkel question Kerr Defender Technical Discussions 49 April 21st, 2004 12:08 PM
