yet another radio code question - Defender Source
Old May 25th, 2005, 05:03 PM
GliderKing's Avatar
GliderKing
Robert Bingham
97 ST D90
I just got my 110 (yippee) but they disconnected the battery on the car carrier. I think I have the code, but don't have a manual. the question is. what is the exact key sequence on the radio? I have a 5 digit code transmitted by the seller, but have no idea if it's just me, if the code is incorrect, or if there is special keys. The radio beeps when any 5 keys are touched including + - menu, etc.
Bob
Robert Bingham
1997 NAS 90 ST
1985 110 RHD 300tdi ROW
@gliderking instagram, twitter
Old May 25th, 2005, 05:15 PM
tron's Avatar
tron
Thomas F
Recently Roverless
Bob--
Land Rover keeps a database of the codes. Just call them to verify...they probably need the VIN or something. Also, if you enter it incorrectly more than (3 times I think) it will just display dashes. I am going to try and remember what the guy at the dealership told me, but I think you hold down the "AM/FM Band" button and the code button at the same time for 5 seconds to reset it. Someone please correct me if I am wrong.
Tom
Old May 25th, 2005, 06:32 PM
BarryO
Barry O'Mahony
97 D-90 SW LE
In a 97, if you enter is incorrectly too many times, it cuts out for a few hours.
Also, I ran into own problem that is not well-documented: sometimes when you connect the power, the radio doesn't rest properly, and it won't accept the code. You need to disconnect the battery, wait a little while, and re-connect it.
Old June 4th, 2005, 05:06 PM
bbandit
William Baker
1997 Defender 90
Radio Code problems
I called the local dealer for the radio code for my '97 D-90. In typical Rover fashion, they gave me a 5 digit code which is incorrect. Apparently the codes that they have matched to the VIN on quite a few 1997's is incorrect. The only way to get the correct 4 digit code is to pull the radio and call them with the serial number which is stamped into the metal case on the stock Clarion. Hope this saves somebody else from waiting more than an hour for the radio to reset after they put the wrong code in 3 times :-)
Bill Baker
radio
Code 17 Question loved90 Defender Technical Discussions 3 December 22nd, 2011 05:14 PM
Radio Code Help? ;) wicks Defender Technical Discussions 7 December 31st, 2009 07:59 AM
Quick radio question - '97 SW Captain Spalding Defender Technical Discussions 3 July 5th, 2009 01:26 PM
110 Radio Question bjf Defender Technical Discussions 0 June 20th, 2009 07:34 PM
Radio Code Woes Krna Misc. Chit-Chat 5 November 19th, 2008 01:20 PM
