Yet Another overheating thread - Defender Source
Old August 7th, 2010, 03:08 AM
Defender90_218's Avatar
Defender90_218
Trenton Smith
1997 D90
Has anyone experienced overheating at highway speeds that returns to normal by slowing to city speeds/sitting. It seems backward from most of the other overheating threads I can find.
Heres what I've done so far to no avail.
Rad. Flush
New hoses
New water pump
New thermostat
Old August 7th, 2010, 08:04 AM
draaronr's Avatar
draaronr
Here
LR3
your radiator is crap.
Old August 7th, 2010, 04:42 PM
jhhorse
joe heins
1995 defender 90
I would say check your sender and gauge, make sure they are working properly. My D-90 runs hotter at highway speeds, or when climbing a long hill, etc, The gauge looks like it is getting ready to overheat, but after checking the actual temp of the engine, hottest it gets is about 210 degrees F, I think this is fairly normal temp and my gauge just reads high. I have checked the rad, no hot spots, coolant comong out of rad is about 35 degrees cooler than going in.
Old August 7th, 2010, 06:25 PM
Defender90_218
Trenton Smith
1997 D90
It's actually over heating, its boiled over a couple of times when I couldn't stop in time
Old August 7th, 2010, 07:40 PM
kellymoe's Avatar
kellymoe
kevin
defender 130
When my truck did this it turned out to be a radiator cap with a bad gasket. New cap cured everything.
Old August 9th, 2010, 09:24 PM
Davis's Avatar
Davis
Chris Davis
94 NAS D90 6.2LS
Could be the cap, clogged radiator, stuck thermostat, head gaskets, porous block, slipped cylinder. You can rule out the last three with a block tester (about $60 from Napa). Personally, I would start by checking the cap, then thermostat then the block test. From there, I would pull the radiator and have it checked out (or get an IR thermometer and check it yourself) and/or get the fluid block test from NAPA and check that. The most expensive part of this procedure is the radiator check mainly due to the time/inconvenience of pulling the radiator which is not hard, just not fun.
defender, overheating, radiator, thermostat, water pump
Another overheating thread Devin W Defender Technical Discussions 37 August 14th, 2007 01:35 PM
Tailgating the overheating thread by steve bd90 Defender Technical Discussions 1 April 4th, 2006 12:34 AM
Transfer Case Lever Thread Size? ronward Defender Technical Discussions 4 August 30th, 2004 02:26 PM
Thread rating options chrisvonc Community News & Announcements 0 July 2nd, 2004 09:49 AM
Thread hijacking! TwisteD90 Misc. Chit-Chat 19 March 6th, 2004 03:23 PM
