Year range for 4.6 swap - Defender Source
Old August 23rd, 2009, 07:50 PM
kolvedic's Avatar
kolvedic
Bill Lewis
1995 White SW 339/500
I was wondering if I am considering a 4.6 engine swap, is there a year range I need to look at? I have a 95 d90 SW. I tried searching and found a lot of great information about all the things you would need, but didn't see anything about year limits.
bill
Bill
Old August 23rd, 2009, 09:23 PM
Any is fine since you only reuse the block and maybe the heads.
Old August 23rd, 2009, 10:18 PM
Grover's Avatar
Grover
Question
What about the ecu? Does it need to be re-mapped?
Cheers...
Old August 24th, 2009, 08:57 AM
Hoosier's Avatar
Hoosier
Chris Hinkle
More than I need
Remapping or rechipping will depend on whether you want to put in a performance cam and rechip for more power.
Old August 24th, 2009, 12:18 PM
Grover's Avatar
Grover
Question
So how much power will a 4.6L give over a 3.9L with the stock 3.9L ecu/chip?
Old August 24th, 2009, 03:05 PM
+20-30hp, +40-50ft/lbs
Old August 24th, 2009, 03:08 PM
rover26c's Avatar
rover26c
Lee
1994 D90 ST
Aren't you suppose to update the ECU chip when replacing the engine from 3.9 to 4.6?
Old August 24th, 2009, 03:17 PM
btate
Bryan Tate
d90
Yes, if you don't it will knock with full throttle.....ask me how I know
Old August 24th, 2009, 07:01 PM
The 3.9/4.0 has 182HP and the 4.6 has 222. So, about 40 HP is it's stock form.
Old August 24th, 2009, 07:05 PM
A 4.2 chip works fine.
Old August 24th, 2009, 09:35 PM
Tyler Wirken
Tyler Wirken
1997 Defender 90 LE
Glad to see this thread as I am seriously considering swapping in a 4.6 on the 110 project. I have a 4.0 and it was pretty good with 35's and 4.10's on a 90 but I fear it will not be enough as a 110. Would 40 extra horsepower be worth the money on a 110? What is the best way to hop up a 4.6 and how much can you really get out it?
Just need a bit of schooling on this.
Tyler
Old August 25th, 2009, 12:47 AM
d90dan's Avatar
d90dan
Dan Berry
1995 D90
Maybe I am missing something but why got with a 4.6? What's wrong with modifying a 3.9?
I've had Buick heads/intakes race ported for under $1000, pocket ported for much less. I'm not up to date with 3.9 cam pricing, but I'm guessing $500 max with lifters. If that doesn't give you 40hp, something went wrong.... So about $1500 for the top end.
If your bottom end needs a rebuild then maybe it makes more sense, maybe not. To professionally freshen race motors locally its about $1500, if the hard parts are good.
So if your 3.9 is in decent shape I would guess 3k to freshen it up and add at least 40hp.
Is a 4.6 long block cheaper?
Old August 25th, 2009, 03:37 PM
cdb
Clark Bowen
re: Modifying a 3.9L
What about torque?
Wouldn't those mods just give you more power on the upper end? But maybe he wants a highway cruiser - I don't know.
2011 RR HSE -
2001 GMC 2500 4wd
Old August 25th, 2009, 03:42 PM
kolvedic's Avatar
kolvedic
Bill Lewis
I would be interested to know if anyone has done this and what parts they used. My 3.9 is in pretty good shape but I just want a little more umph on the road. I am not looking for a race car, but climbing hills on the highway without down-shifting would be nice. I will try searching around for 3.9 and cam to see what I can find.
I had also considered a gear change, but again not sure if that would be a way to go. I think I read in one of the many searches that it could help.
thanks guys,
Bill
Bill
Old August 25th, 2009, 03:43 PM
4.6 has cross-bolted mains
1993 Range rover transfer case swap easy Defender Technical Discussions 2 August 6th, 2009 10:18 PM
Famous Land Rover owners Lindy Misc. Chit-Chat 4 June 15th, 2009 08:49 PM
Land Rover family tree D901619 Defender Technical Discussions 9 July 5th, 2007 04:34 PM
Range Rover Parcel Tray roverboy For Sale - Parts 1 November 16th, 2005 10:29 AM
