Ye Olde Low-idle Problem - Defender Source
Old October 6th, 2006, 12:51 AM
chris snell's Avatar
chris snell
Chris Snell
87 Ex-MOD 110
Hi,
Like many folks here, I'm having problems with my truck idling low (300-400 RPM, barely above stalling) when I take my foot off the throttle. Here's the strange thing: it happens only intermittently; air temperature nor engine temperature seem to have any affect, nor does altitude. It happens up here in Park City just as it does Salt Lake and down in Texas. It happens about every 15 starts or so. If I turn the truck off and let it sit for a 20 seconds or so, I can start up again without any problems.
I have run Seafoam through my throttle body several times, run Lucas fuel additive, etc., but the problem persists. I thought about monkeying with the idle adjustment but this seems to be a cop-out because the problem is intermittent.
What do you think the problem might be? MAF? TPS?
thanks,
1987 Ex-MOD 110 Tithonus LHD
2013 LR4
Old October 6th, 2006, 08:02 AM
Andrew Vick
Andrew Vick
95 D90
IAC or stepper motor need cleaning or replacement? Any vacuum leaks?
Old October 6th, 2006, 10:34 AM
Davis's Avatar
Davis
Chris Davis
94 NAS D90 6.2LS
I would start by cleaning the stepper motor. Some people remove the spring, I have not noticed a difference one way or another and one of my trucks has it removed. Regardless, sometimes the pluger sticks when it gets dirty and the symptoms are as you describe. Won't cost a thing but a few minutes.
Old October 6th, 2006, 10:35 PM
chris snell
Chris Snell
87 Ex-MOD 110
Ok, I'll try that, thanks guys. Service manual says I need to re-fit it using a new washer...gotta find one of those.
No vacuum leaks as far as I can tell. I suppose I could do the (scary) carb-cleaner-on-the-hoses trick...
2013 LR4
Old October 6th, 2006, 10:43 PM
Andrew Vick
Andrew Vick
95 D90
Shouldn't be that scary, and I wouldn't worry too much about the gasket. IIRC, the gasket is essentially a butcher paper thick piece that you could easily replicate.
Old October 7th, 2006, 01:23 AM
Davis's Avatar
Davis
Chris Davis
94 NAS D90 6.2LS
I agree on the gasket, but mine is green, so you may want to find green construction paper. ;-) Quite frankly either by the $2 gasket or get some gasket paper from Checker auto and cut one. Except then it would probably be black in lieu of green, and with a rover, that could make all the difference!
idle
Idle problem - Throttle position sensor? JBfoot Defender Technical Discussions 20 January 7th, 2008 11:45 AM
High idle problem MAF ? TPS? other? MonLand Defender Technical Discussions 30 February 5th, 2007 03:33 PM
97 Idle Problem gtg067i Defender Technical Discussions 2 January 8th, 2007 09:28 PM
Idle problem - need advice fleabus Defender Technical Discussions 24 February 7th, 2006 06:36 PM
The latest show-stopper: dies at idle, only runs above 2K rpm jaherring Defender Technical Discussions 34 December 23rd, 2004 07:05 PM
