Yay, new skid-plate time.... - Defender Source
Old February 27th, 2007, 01:20 PM
Hans's Avatar
Hans
Hans Haase
The D-90.com Lab Rat
Well, the skid plate under the fuel tank has finally said "Hey, I'm rusted out and falling apart". So, a new one is on the way from SlickRock thanks to you guys suggestions.
So I'm looking for some advice on how best to go about this. I'm going to get me some PBlaster, soak it down for days before the swap, but I'd like to pick up some new hardware ahead of time as well. Anybody know which bolts I'm going to need?
And also, any good tips for the actual removal process?
-Hans
My oil line fix
My 100k stopped odometer fix
Old February 27th, 2007, 01:59 PM
dave_lucas's Avatar
dave_lucas
Dave Lucas
PB Blaster, PB Blaster, PB Blaster, and then some more PB Blaster
Start now and keep spraying all of the bolts
Use as much gas as you can from the tank before you start the job, that stuff is heavy
Might also want to have a drill on hand, new bolts and a proper size tap.
Old February 27th, 2007, 02:21 PM
Flagg's Avatar
Flagg
Flagg
1995 Defender 90 NAS
Hans - I cut and pasted this from an old message that I had written on this board. This was the experience that my shop had with my gas tank skid plate! Good luck!
Flagg
I just had my gas tank skid plate replaced. My rover shop said it was really shot - and holds some of the wieght of the gas tank. I went with the new Rovers North heavy galv. unit. I know everyone will scream at me for not going stainless - but the repair dollars keep adding up, and I figure the galv. will last a very long time. I had to save money somewhere.
Anyway - it ended up being a bigger job then planned. All the bolts were rusted and had to be drilled out..........and many of the connections for the new bolts were gone. They had to find points to weld new attachment points. Because welding was involved they had to remove the gas tank......
I hope yours in not that bad - but I wanted to forwarn you in case, so you will have heard of it. Also, make sure you go in with a near empty gas tank. When they remove the skid plate they have to support the gas tank........at 6 lbs +/- for a gallon of gas - having a full tank or a 1/4 tank makes a big difference.
Old February 27th, 2007, 02:56 PM
artm
Arthur Maravelis
97 SW
May be a good time to replace the fuel pump - depending on how many miles you got on it. Better yet, cut an access panel for it.
Old February 27th, 2007, 03:27 PM
flippedrover's Avatar
flippedrover
Tyler
'94 D-90
Go slowly when removing the bolts. After the PB soaking I loosened then tightened the bolt I was working on over and over backing it out a little more each time so I wouldn't snap it. Worked on all but one bolt. Ratchet straps under the tank are your friend. A floor jack helped keep the plate from falling on my head.
Jimmy Buffett
Old February 27th, 2007, 04:32 PM
brn24whl's Avatar
brn24whl
Eric
1994 RRC SWB
I have replaced a few and I use a rachet stap between the tank and the skidplate to hold the tank in place when the plate comes off.
Eric
Eric Riston
1-800-533-2210 ext 231
Direct Line 518-539-2231
Old February 27th, 2007, 09:23 PM
Defender13's Avatar
Defender13
Mike Lynch
1994 Defender 90 #1017
I did mine last year and I cound not believe the condition of the skid plate. It's not as bad as some that I have seen here in some other posts. Like Tyler said, just go back and forth and keep the PB Blaster going. I soaked mine every monring for a week before I even got started. I ended up breaking one bolt which was a pain the in ass, but considering how difficult it was to get all of them out I am suprised that I only broke one. I put some anitseize on all of the bolts once I installed the new plate. I wedged a 2x4 between the axle and the lip of the gas tank to hold it up while replacing the plate. Worked out pretty good.
Good luck
Mike Lynch
Old February 27th, 2007, 11:02 PM
Hans's Avatar
Hans
Hans Haase
LOL I think mine is going to be on the "That's pretty bad" pile once it comes out. It looks pretty fully destroyed already, and is starting to collapse. When I was on the phone today, I even recalled using the phrase "whichever version you can ship quicker".
One specific thing I'm curious about is how much of a pain in the butt the anti-sway bar is. Do you have to remove it totally? Or do you just need to do the bolts going through the skid plate, and move it out of the way?
-Hans
My oil line fix
Old February 27th, 2007, 11:31 PM
Defender13's Avatar
Defender13
Mike Lynch
you will ony have to remove the bolts on the skid plate. the sway bar will swing down out of the way. i replaced the bolts while i was replacing the skid plate.
Mike Lynch
Old February 28th, 2007, 07:11 AM
vesparover's Avatar
vesparover
brian bertolini
Be careful lowering your tank- When I did the lines were corroded and snapped at the fuel pump. Sucked.
Brian Bertolini
Old February 28th, 2007, 09:12 AM
ron's Avatar
ron
Ron
1994 NAS Defender 90
First clean the area around the tank with a presure washer.
Mine had so much sand and mud that the PB did not penatrate at first,
then PB Blaster, PB Blaster, PB Blaster, and then some more PB Blaster
as Tyler said
"After the PB soaking I loosened then tightened the bolt I was working on over and over backing it out a little more each time so I wouldn't snap it"
I used SS bolts and dumped the rear sway bar
My tank was almost empty and I supported the tank with 2 long screwdrivers thru the sides of the tank.
Good luck and take your time
Old February 28th, 2007, 11:24 AM
flippedrover
Tyler
'94 D-90
You're still running your sways? Why did I think they were gone.
Jimmy Buffett
Old March 8th, 2007, 08:42 PM
Hans's Avatar
Hans
Hans Haase
Well, wasn't anywhere near as bad as I had feared. Only two snapped bolts, the high ones all the way in the back. Oh wait, and two more that are part of the swaybar brackets, but those I can grind the nuts off any I'll be fine. What a massive improvement the Slickrock plate is, and dear god was the original one in bad condition.
I should be all finished up tomorrow, horray!
-Hans
My oil line fix
Old March 9th, 2007, 12:32 AM
dave_lucas's Avatar
dave_lucas
Dave Lucas
Old March 9th, 2007, 08:24 AM
Andrew Vick
Andrew Vick
95 D90
I wonder what his sliders look like?
Fuel tank skid plate GeoParth Defender Technical Discussions 53 June 25th, 2006 03:21 PM
Fuel Tank Skid Plate sgarrett For Sale - Parts 2 April 10th, 2005 04:09 PM
Skid plate mounting anyone? Cube II Defender Technical Discussions 5 August 23rd, 2004 04:06 PM
Brand new SG skid plate for sale Chris Cox For Sale - Parts 6 January 29th, 2004 09:19 AM
Stainless steel gas tank skid plate dave_lucas For Sale - Parts 27 December 26th, 2003 11:48 PM
