XM Radio antenna install Location - Where? - Defender Source
Old April 6th, 2004, 12:18 AM
COSteve
Steven Reed
93 Defender 110 - #107
As I run my truck over miles of wash board road in the summer, I am been saving my pennies for a XM radio in lieu of the CD skipping. Finally got the OK from the better half and had it installed. On of the things I ran into was where to put the small flat XM antenna. The crew at CarToys here in CO came up with the perfect location.... Under the Left Wing Vent! It sits on its own metal bracket (needed for reception) the vent is not obstructed, and it is completely out of the way with no wires exposed. Just wanted to pass it along as it is working great!Cheers! COSteve
Old April 6th, 2004, 11:17 AM
januconn92's Avatar
januconn92
Jan Jurgielewicz
97 D90 #1477 Green ST
Sat. Radio
Personally, Sirius is my choice, NFL, NBA and better music, but opions are like .....
Anyway, I'm building a metal bracket to mount on the brakelight bracket, then use the magnetic antenna...
Either way, Sat Radio is truly amazing.....
Old April 6th, 2004, 11:51 AM
chrisvonc's Avatar
chrisvonc
Chris von C
No Defender at this time
I completely did away with the little antenna and went to one of the larger ones and mounted it to the rear door. After having it there now for a year, the only change I would make is to mount it on the right side of the tire. Its easy to forget that its not strong enough to use as a handle to close or open the door and being where I have it now I catch myself reaching for it.
Chris von C
[/size]
Old April 6th, 2004, 02:55 PM
loykd's Avatar
loykd
Ken Loy
1994 Portofino Red ST
How well can you hear it with your STs? Are you driving with headphones or are the Badger tops that good at keeping out the road noises?
Old April 6th, 2004, 03:02 PM
Ken the type of radio signal or even a CD will not make that big of an impact on how well you hear it as much as better speakers and a good amplifier. Although CVC's XM sounds good!
Old April 6th, 2004, 03:03 PM
chrisvonc's Avatar
chrisvonc
Chris von C
add a 300w amp, jbl front speakers and bose rears with volume WAY up on highway.
Chris von C
[/size]
Old April 6th, 2004, 03:15 PM
loykd's Avatar
loykd
Ken Loy
front speakers in the door or elsewhere? I saw someone at MAR two years ago with 2" tweeters in the dash, just outboard of the windshield defrost vents. I was wondering if that works well on the road.
CVC, with that big stereo, do I also need to get hyd lifts, neon lights and fuzzy dice?
Old April 6th, 2004, 03:25 PM
chrisvonc's Avatar
chrisvonc
Chris von C
Replaced the front speakers with the marine JBLs. You will need to get a set of bling spinners though.
Chris von C
[/size]
Old April 6th, 2004, 07:12 PM
loykd's Avatar
loykd
Ken Loy
I thought I knew what you were talking about until I did the google search on 'bling spinners'. Do you think they make these for Buck's 37s?
http://www.rcmodels.com/pro602600.html
Spinning…to rotate or to cause to rotate swiftly. And that’s exactly what Pro-Line’s new 40 Series Spinner will do when you install it with your 40 Series Pro-Line wheels.
The 40 Series Spinners represent the latest craze in wheel add-on styling. While on the move, the spinners rotate slowly making it seem like your monster truck is at a stand still as it screams by you. On the other hand, while you’re screaming down the road and you come to a stop, the spinners spin at a super high rate making it seem as though you’re moving at high speed.
The 40 Series Spinners adapt to Pro-Line 40 Series Velocity 6 and Mambo wheels with ease. Two ball bearings allow the spinners to rotate separately from the wheel. 6061 aluminum is used to enhance the performance of the spinner. Each spinner is hand polished and machined by the latest tooling technology.
When you’re looking to spin your way down the street or at a stop, check out the latest wheel accessory technology—the 40 Series Spinners from Pro-Line.
Features:
· Stopped on the move, spinning while stopped · Made from 6061 aluminum · A gleaming polished finish · Full ball bearing equipped for unmatched smoothness · Kit includes 2 faces, 3 adapters (2 right-hand-thread, 1 left-hand-thread), 4 ball bearings, and 2 screws
oops, maybe this is an example of thread hijacking... Sorry Steve. I'll google 'bling satellite antennas' next time
Old April 6th, 2004, 07:26 PM
Art Vigil's Avatar
Art Vigil
Arthur Vigil
Some things are just wrong.... spinners
Arthur M Vigil
Colorado Native
Former owner of:
'95 RRC - 3.9V8 Rimmer Supercharged!
'72 Series III 88" NADA Turner 2.25 petrol (Lovely Rita)
'95 RRC Brooklands/TWR Edition 3.9V8
'97 D90SW NAS #2426 - 3.9V8 Rimmer Supercharged!
'95 D90ST NAS#2620 - Original owner
Old April 6th, 2004, 08:24 PM
Eric Siepmann
Eric W. Siepmann
1997 Defender 90 SW
They have their place. They aer after all ghetto rich.....
EwS
Old April 6th, 2004, 08:58 PM
COSteve
Steven Reed
Hijacked maybe..... but the banter is well worth it!
Old April 6th, 2004, 09:47 PM
flippedrover's Avatar
flippedrover
Tyler
'94 D-90
Hey Ken we were listining to my XM at the camp site Sat night. I've got the stock speakers and hear them fine with and without the top. Only have to remember to turn it down after I get off the interstate. I mounted the antenna on one of the light tabs on the cage. Low profile mag mount off of my pickup.
Jimmy Buffett
Old April 6th, 2004, 10:59 PM
mdmccallum's Avatar
mdmccallum
'97 Defender 90 SW
Same here Tyler. Mounted on the Light tab. Works fine. I had some reception problems with it mounted on the rear of the 90. Steven, any chance of getting a pic of your mount?
Old April 6th, 2004, 11:01 PM
chrisvonc's Avatar
chrisvonc
Chris von C
We bought the XM "boom box" for camping. Pop the head unit in and you are jamming by the campfire.
Chris von C
[/size]
Old April 7th, 2004, 12:30 PM
COSteve
Steven Reed
Installed Pic of XM under left Wing Vent
They also did a great job on the JL Audio Amp under my bench seat with enclusure and cooling fan. Will post if anyone is interested....
Old April 7th, 2004, 07:53 PM
OCD90's Avatar
OCD90
Torrence
1997 Hardtop
So, the antenna isn't even on the surface? It's able to get the signal from under the wing vent through the plastic? Also, I'd heard it had to be "Line of Sight"...doesn't the cab affect signal at certain angles that low?
And, yes, I'd like to see a pic of that amp posted here.
Thanks! Such a help, everyone.
Old April 7th, 2004, 10:48 PM
COSteve
Steven Reed
Thumbs up XM Reception and Amp Picture
The XM antenna top is right below the plastic of the wing vent cover. CarToys cut the ridges down that are on the bottom side of the wing cover to get the antenna as high as possible. They also mounted the metal "L" bracket that the antenna sits on with its magnets. I have not run into reception problems at all, all driving directions are good (Hyphoticially- driving north would pose the most interferece of the body of the truck).
The JL Audio 300/4 Amp is under the enclosure that they fabricated, under the bench seat. As it tumbles with the seat, it gives up miminal cargo space. Fan is there to keep it cool. Now if I can just get the truck to stop marking its territory on the garage floor!
Old April 8th, 2004, 12:34 PM
Joe P's Avatar
Joe P
Joe Pfeiffer
Black 97 D-90ST #0605
Where did you install the XM unit. Could you take a picture?
If the truck makes it - the trail wasn't tough enough.
If the truck doesn't make it - the truck wasn't tough enough.
Old April 8th, 2004, 01:02 PM
loykd's Avatar
loykd
Ken Loy
Steve, That's very interesting on the antenna mounting. I never would have thought that you'd not suffer signal reception degradation from the body panels.
Back to the speaker question, what did you install to go with that massive amp? (Besides the bling spinners, of course)
radio
1997 Radio Antenna Removal ronward Defender Technical Discussions 12 August 8th, 2007 08:21 PM
'97 D90 radio install help Defender50th Defender Technical Discussions 0 October 18th, 2005 03:19 PM
satellite radio antenna install nykx Defender Technical Discussions 8 November 29th, 2004 10:49 PM
Power Radio Antenna Kimos Defender Technical Discussions 0 October 21st, 2004 08:45 PM
ST Radio Location javelinadave Defender Technical Discussions 5 August 6th, 2004 09:09 PM
