Xfer Case Leaking - Page 2 - Defender Source
Old July 24th, 2014, 08:21 AM
must be the rear output? yours looks dry compared to mine
Old August 6th, 2014, 05:01 PM
I have everything torn apart and I ran into something that I have NOT seen on any of the tutorial vehicle pictures online. My transfer case has an extra piece that covers the oil seal cover that I circled in red.
Do the bolts holding it on go thru into the transfer case requiring me to reseal the bolts when I reinstall them?
Does that bracket do anything other than stump me?
Old August 6th, 2014, 05:06 PM
Brewie212's Avatar
Brewie212
Brian Kandefer
To the best of my knowledge I have never sealed the four retaining bolts for the rear parking brake assembly.
Old August 6th, 2014, 05:08 PM
Roadsiderob's Avatar
Roadsiderob
Robert Dassler
1994 D90
Bolt holes are blind. The part is an oil catcher that directs the oil to the drain slot in the casting. Keeps the shoes from getting too much oil contamination when the seal leaks.
Rob Dassler
SWR Automotive
505-872-7818 (shop)
Old August 6th, 2014, 05:15 PM
Thanks all! I'm trying to avoid creating a leak while fixing a leak. My love-hate relationship continues and the smell of 90wt gear oil makes me nauseated.
Old August 6th, 2014, 05:17 PM
Viton's Avatar
Viton
Deaf Ember
Smart 4x4
Why does gear oil have to stink so bad ?
Old August 6th, 2014, 05:22 PM
Synthetic 90wt smells less.
Old August 6th, 2014, 05:25 PM
Lets hope so, I'm refilling it with Red Line synthetic.
Old August 6th, 2014, 05:27 PM
Roadsiderob
Robert Dassler
1994 D90
It's like cow shit....smells like money!
Rob Dassler
SWR Automotive
505-872-7818 (shop)
Old August 6th, 2014, 05:34 PM
Bill Larson's Avatar
Bill Larson
Bill Larson
Nice!
Old August 7th, 2014, 11:46 PM
Done and done.
A few lessons to share for anybody who is interested:
1) The most time consuming part of the entire project is removing and reinstalling the 4 nuts that hold the driveshaft on.
2) Once unbolted if you raise the body of the truck (floor jack under the hitch) up a few inches to "stretch the drivetrain" the driveshaft easily pulls away from the transfer case.
3) Loosen the 30mm nylock nut before you pull the parking brake drum and loosen it while the parking brake is set.
4) Grease the seal well and set it in using your 52mm hub socket.
5) Finish torque down the 30mm nylock nut after you reinstall the parking brake drum and set it.
6) Synthetic gear oil smells WAY better than standard gear oil.
Old August 23rd, 2014, 08:29 AM
on the rectangle inspection plate do most people use the rubberish gasket or RTV?
Old August 23rd, 2014, 09:03 AM
Iamkraig's Avatar
Iamkraig
Kraig
1987 defender 110
I have used "right stuff" on the couple I did and it seems to hold up well.
Old August 23rd, 2014, 09:13 AM
Everyone should have one of these: http://www.paddockspares.com/da1119-...-14-50gbp.html
Personally, my hand brake comes off at least once a year for a clean and lube. You can probably do the whole job in an hour once you've worked out the easy way to get things off.
Old August 23rd, 2014, 10:24 AM
I only ever use Right Stuff. Whoever resealed my transfer box used a gasket kit, and it leaks.
Originally Posted by Red90 View Post
I used to have one of those, and it was nice, but I dropped it into one of the in-ground lifts at work. Since then, I've just been using a 9/16' shallow socket with a wobble extension.
Old August 23rd, 2014, 02:39 PM
does anyone RTV the plate that the input gear bearing race lives in, it is sandwiched between the transfer case and the round PTO cover.
Drain Plug Diffs/Xfer Case Grover Defender Technical Discussions 7 November 11th, 2009 11:21 PM
Xfer case Fail Abrooks Defender Technical Discussions 17 March 31st, 2009 10:00 PM
WTB: D1 Transmission and Xfer Case PCRover Wanted 9 March 14th, 2008 11:11 PM
EMERGENCY-Xfer case issues Cyborg Defender Technical Discussions 7 July 18th, 2004 02:50 AM
97 trans/xfer into 95 Disco boxerhips Defender Technical Discussions 4 June 10th, 2004 01:08 AM
