Xfer case Fail - Defender Source
Old March 7th, 2009, 05:46 PM
Abrooks's Avatar
Abrooks
Tony Brooks
Xfer case Fail
So this is bad, right?
Anyone have a rear output housing for an early LT230 that has the speedometer drive?
Old March 7th, 2009, 05:54 PM
Bozman's Avatar
Bozman
Greg
1991 200tdi D90
Doht!
I'll give you $700 for that 110, no questions asked.
Old March 7th, 2009, 06:10 PM
Abrooks's Avatar
Abrooks
Tony Brooks
This truck is going to be the end of me. I'm really not feeling it right now.
Old March 7th, 2009, 06:13 PM
pendy's Avatar
pendy
jim pendleton
89'd90
A speedo is over-rated.
I can dig one up for you if you have no luck elsewhere.
legend in my own mind
Old March 7th, 2009, 06:15 PM
Abrooks's Avatar
Abrooks
Tony Brooks
It's a much having to try to retrofit the cable for the parking brake assembly as it is the speedo/odometer. I'll give you a call if I can't find another one. Thanks!
Old March 7th, 2009, 06:25 PM
Wolf Fabrication's Avatar
Wolf Fabrication
Sterling Archer
'08 D3
I am waiting for the right moment to swoop in and lick it!
Semper Fi!
Old March 7th, 2009, 06:29 PM
Abrooks's Avatar
Abrooks
Tony Brooks
Anyone know off hand what trucks came with transfer cases with the speedometer drive?
Old March 7th, 2009, 08:28 PM
pendy's Avatar
pendy
jim pendleton
89'd90
I do not think Rob will part with that piece. He needs them s much as I do. The later DII Lt230's had the housing with no speedo drive. They used ABS for the speedo. Good news is you have a very late midel case. Those cases were built with more heft then the earlier ones.
Get a big drill bit and go for it!
I agree on the disco drum brake and happen to have one for sale.
How is the hand rehab?
Whoops did not pay attention though you had a different problem. You can drill and tap the housing for the parking brake. The housing comes off the back with no bearing preload if you do not want to remove the transfer case. Just reseal it with right stuff.
I thought you had a late model case without speedo drive you were trying to sort.
Old March 7th, 2009, 08:39 PM
Abrooks's Avatar
Abrooks
Tony Brooks
Is it possible to modify the exisitng (d2) cover for the speedo drive? I do have the d2 parking brake and cable,I'm just not sure if I have all the pieces in the linkage internal to the brake. Was hoping to just use the existing one, but if I can get that on to the box with the speedo drive, I might be in business. End of the day I'd prefer to not have to eff with this anymore as it'll be another 2 weeks until I can turn a wrench again.
Hand is much better, thanks. Still building strength back up, recovery has taken longer than I was hoping it would.
Old March 7th, 2009, 10:50 PM
Roverowner's Avatar
Roverowner
Brian Love
95/Disco
count my Xfer case in the dead column. I can go into low (that is how I got home), but normal the truck just sits a revs. The interesting thing is that the speedo moves too (when it just spins). Does that mean anything?
Inspirational Thought of the Day
Some people are like Slinkies ...
Not really good for anything, but they still bring a smile to your face when
you push them down a flight of stairs.
1995 Discovery
Old March 8th, 2009, 01:20 PM
Roadsiderob's Avatar
Roadsiderob
Robert Dassler
1994 D90
When it's sitting and revving with the speedo turning, is the rear driveshaft turning? If so, start looking for the problem in the rear axles or rear diff.
Tony,
Call me tomorrow at 505-872-7818. I'm sure I have a housing. I'm concerned about why it broke. Not all the rear outputs are the same. They all look pretty much the same, but the raised area that seats against the bearing is different thickness, depending on what case it came from. The cases that used gaskets are thicker there. If you start mixing and matching parts without this knowledge, you can mess up the bearing preload and possibly have a breakage such as you did. When you call me, can you give me the serial numbers off of both old & new boxes? That way we can come up with a good combination of parts & gaskets.
Rob Dassler
SWR Automotive
505-872-7818 (shop)
Old March 8th, 2009, 03:32 PM
Roverowner's Avatar
Roverowner
Brian Love
95/Disco
Thanks for the hint, I'll start checking that out now....
rear drive shaft spinning away in drive...need to find a lift and a second set of eyes....
1995 Discovery
Old March 8th, 2009, 05:52 PM
You broke a half shaft or blew the rear diff. Betting its the short side halfshaft. A lot quicker and easier to repair.
You should have been able to drive the truck in high range diff lock.
Old March 8th, 2009, 09:39 PM
Roverowner's Avatar
Roverowner
Brian Love
95/Disco
Didn't get to back it up yet, but that is the first place I will look. Thanks for the info....I'll report back with my findings.
1995 Discovery
Old March 31st, 2009, 09:21 PM
Roverowner's Avatar
Roverowner
Brian Love
95/Disco
It was the Rear Diff. the whole thing needs to be replaced. The question is, why is the Atlantic British rear diff only $1000 but all the other ones are $3-4K? Is there something I am missing?
1995 Discovery
Old March 31st, 2009, 09:23 PM
Abrooks's Avatar
Abrooks
Tony Brooks
Call Tillery, I'm sure he could get you a suitable replacement for a fraction of the price.
Old March 31st, 2009, 09:28 PM
Roverowner's Avatar
Roverowner
Brian Love
95/Disco
Tillery?....sorry, need a little help...
nevermind....figured it out.
1995 Discovery
Old March 31st, 2009, 10:00 PM
Diffs are $100 all day.
transfer case questions HELP! mattwhite Defender Technical Discussions 2 March 8th, 2009 02:45 PM
WTB: D1 Transmission and Xfer Case PCRover Wanted 9 March 14th, 2008 11:11 PM
Transfer case output nut size? Trigger Defender Technical Discussions 5 April 12th, 2005 03:32 PM
Rover Expedition Case w/ 4 walkie talkies jack frisch For Sale - Parts 0 February 27th, 2005 03:24 AM
transfer case redrover Defender Technical Discussions 9 January 27th, 2004 02:41 PM
