XCase Rear Output Seal - Defender Source
Old August 25th, 2010, 02:13 PM
Viggen's Avatar
Viggen
Jarrod
none
So, the handbrake isnt working on my '95 D1 because there is a seep in the output seal into the drum. I have the parts but as I looked through Haynes, I realized there was nothing on it. The seal cant be too hard to do. Undo the nut, pull the flange and then the mud shield and then the seal itself. Install is the opposite. My question is about the torque figure on the flange nut itself. Anyone know and have any tips/ tricks for the job?
Old August 26th, 2010, 09:36 AM
MonLand
Loic Fabro
95 D90 - 96 Disco -06 LR3
Soack (and let it sit overnight) the brake pads into something (brake cleaner fluid seems the obvious) to try to remove as much oil from the pads as possible. This is going to be the trickiest part of the job!
No trick to do the job, but in my case, the T-case (I assume that's why you mean by "xcase") was out of the truck, so it was easy to do input and output seals. I don't recall bothering with the torque, you will feel how much torque you will need to get it out. Likely, I put some blue thread locker to avoid having it backing out if there is no other locking mechanism.
MonLand
1995 D90 NAS
1996 Discovery NAS
Old August 26th, 2010, 10:33 AM
D90user's Avatar
D90user
steve
109/110 ambulance-55 series I
last time my rear output was leaking it was the nut no the seal. I was all ready to do the whole change, took it apart, and the nut was a smidge loose and oil was passing by the felt washer.
use locktite.
Old August 26th, 2010, 11:49 AM
wcampbel@nas.edu's Avatar
wcampbel@nas.edu
Bill Campbell
1994 D-90 ST
use locktite.
Same here on my 94 D-90. Did that about 5 years ago with locktite and haven't had a weep since.
B
Transferr case rear output seal redrover Defender Technical Discussions 4 July 29th, 2006 05:21 PM
Which direction to install rear outer hub seal? cgalpin Defender Technical Discussions 16 September 23rd, 2005 12:06 AM
Rear main seal replacement howellm70 Defender Technical Discussions 4 May 20th, 2004 07:33 AM
