X-Jack -- Yay/Nay? - Defender Source
Old February 9th, 2015, 01:45 AM
RBBailey
RBBailey
1965 IIa
X-Jack -- Yay/Nay?
So I've tried this thing in the garage with the Series, and although it works well, I can't see using it on solid ground when I've got a bottle jack and probably a high lift as well.
The trouble is getting it to snug up against frame, and not against exhaust bits, or body panels.
I have not tried it on the Disco or Defender. I suppose it would work well on the Disco with the bumpers.
Also, it takes up a lot of room when stored.
So what do you all think of these?
Old February 9th, 2015, 02:25 AM
psykokid
Jake
1997 Disco
Great for sand, that's where I've used it the most. Used it once to get a truck that was high centered on a rock on the rear diff un stuck. I got mine for dirt cheap so it worked out ok..
Old February 9th, 2015, 04:03 AM
Ray_G's Avatar
Ray_G
Ray Gerber
Much the same as your thoughts; when I've got solid ground I'd go bottle jack much of the time. I'd use it before going to a high lift since I find it to be a lot safer/more stable once positioned correctly. Bear in mind my application is a Disco so getting good exhaust pressure is pretty easy and between bumpers, sliders, etc I've got a fair amount of points to place it under.
My usual storage spot is strapped down to the roof rack, which also works well.
Name:	X jack in action.jpg
Name:	Shakedown roof rack load 12 July.jpg
Old February 9th, 2015, 11:10 AM
dmarchand's Avatar
dmarchand
David Marchand
'97 D90 SW Arles
I think it would work awesome when stuck in mud to get a traction mat under your tires without much effort. Have wanted to try it for that.
Old February 9th, 2015, 11:15 AM
Bill Larson's Avatar
Bill Larson
Bill Larson
Another tool in the box situation...options are always good. 15 miles away from help out of radio range you'll be glad to have it.
Old February 9th, 2015, 11:18 AM
Z.G's Avatar
Z.G
Zack
300Tdi 95 D1
I don't recommend it for p38a owners with dual exhaust, but it is a pretty nice piece of kit.
Old February 9th, 2015, 11:24 AM
fishEH's Avatar
fishEH
Brett Fritzler
94, 95, 96 D1's
I watched 3 guys struggle with one of those for about a 1/2 hour out in Moab one year. The guy had a flat on his LR3. The jack won't work with dual exhaust. Also won't work with any kind of exhaust tip, like on a Borla. He finally got it to work off someone else's exhaust only to have his LR3 drop the suspension when lifted, LOL.
The dude finally stuck a bottle jack under the control arm and had the tire swapped out in a couple minutes.
IMO the X-jack is a novelty and isn't worth the space it takes up. There are too many situations it WON'T work for me to dedicate space on the truck for it.
Stock bottle jack and a Hi-Lift is really the best of everything.
Old February 9th, 2015, 11:28 AM
Bill Larson
Bill Larson
Well for sure make sure your equipment works for your set up BEFORE you his the trail...this may not make sense for you.
Old February 9th, 2015, 11:38 AM
the rover shop
shayne young
I used one to rescue a sand rail that had lost its wheel out in the desert sand dunes.. Worked great for that... I could see it having many uses other than just lifting the vehicle up when changing a tyre.. It can fit in many places where I simply don't want to be crawling around under there using a bottle jack... Also it lets you jack the truck without having to be near it... A bit safer in my mind in certain situations.. I will say they can be a bit difficult to use correctly as they sometimes want to pop out from underneath if it's on a bit of an angle..it also doubles as a campfire beanbag.... Or as we like to call it in Awwwwsraylia. A poof..
Old February 9th, 2015, 12:17 PM
Bill Larson
Bill Larson
And I thought you were going to say campfire beanbag...silly me...
Old February 9th, 2015, 12:43 PM
RBBailey
RBBailey
1965 IIa
Campfire bean bag seals the deal. I'm keeping mine.
Old February 9th, 2015, 01:01 PM
Wolf Fabrication's Avatar
Wolf Fabrication
Sterling Archer
'08 D3
Shit, didn't think of that. Now I actually need to get one.
Semper Fi!
Old February 9th, 2015, 10:37 PM
RovingRyan's Avatar
RovingRyan
Ryan Phelps
84 LHD 110
I like mine..have had and carried it for about five years and prob used it 5-6 times. First bought to use on an lr3. It will work great on an lr3 or any other dual exhaust rig with an exhaust plug on the unused pipe. Will also work off of compressed air.
Ryan
84 110SW County LHD
07 L322 Vogue
ac
Rhino-lining. Yay or Nay? UTRPh Misc. Chit-Chat 16 May 29th, 2014 10:44 AM
Yay, Look What Santa Brought!!! Wolf Fabrication Misc. Chit-Chat 15 December 23rd, 2010 09:39 PM
Yea or Nay? themaxx Misc. Chit-Chat 21 July 4th, 2008 01:29 AM
Rearward facing racing seat. Yea or Nay? Neil McCauley Misc. Chit-Chat 13 June 23rd, 2008 10:42 PM
Yay, new skid-plate time.... Hans Defender Technical Discussions 14 March 9th, 2007 08:24 AM
