X-Fan Thermostatic Size for NAS D90 - Defender Source
Old May 8th, 2016, 06:49 PM
Nooner's Avatar
Nooner
Ryan Noonan
1994 D90 NAS #159
Anyone here used the X-Fan thermostatic switch on their lower rad hose for a 3.9L? Not sure what size to get without draining the system and measuring... And I'd rather not do that till I have the part in hand.
I would guess-timate the 38mm size but I'd appreciate if anyone could throw down with their real world experience. I've emailed them and searched online/zee forums to no avail.
Gracias!
Old May 8th, 2016, 08:41 PM
El Solis's Avatar
El Solis
Chris Solis
Camel Trophy 110 sorta :)
Not sure if this helps but I used calipers to measure the diameter of the hose and it worked well. Mine is a 200tdi so I can't help with size.
Old May 8th, 2016, 08:59 PM
Naplm00
Matthew
I did the same, measured with caliper then bought a temp switch/sensor boss on ebay for about 7 bucks
94 D90 AC fan (the earlier system fan on the thing in front of the rad) evilfij For Sale - Parts 5 October 9th, 2011 02:32 PM
Size of fan bolts on viscous fan clutch imeek Defender Technical Discussions 4 September 26th, 2009 03:12 PM
Clutch Fan with fan 95 D90 3.9L Vadim For Sale - Parts 2 October 16th, 2004 06:19 AM
D90 -- Fan clutch and fan Vadim Wanted 3 August 1st, 2004 01:00 PM
