X-Eng's X-Spring - Defender Source
Old February 19th, 2012, 12:31 PM
cdb
Clark Bowen
X-Eng's X-Spring
Has anyone installed these on the front and how did they work?
http://www.x-eng.co.uk/X-Spring.asp
I have retained springs now, but with the longer reach Bilstein 7100s I could drop a couple inches more with these.
2011 RR HSE -
2001 GMC 2500 4wd
Old February 19th, 2012, 12:52 PM
kinetic's Avatar
kinetic
Kinetic Adventures
TDI's
There was an interesting discussion on Pirate about these I remember reading a little while back. I don't think it was of the favorable tone, but I could be wrong. Either way, just search over there and it should pop up.
Old February 19th, 2012, 04:06 PM
cdb
Clark Bowen
thanks
will do
2011 RR HSE -
2001 GMC 2500 4wd
Old February 19th, 2012, 04:22 PM
Jake1996d1's Avatar
Jake1996d1
Jake
96 Disco/88 RRC
external mounted front shocks? I would also be interested in seeing pics and hearing how it was made work..
Old February 19th, 2012, 11:30 PM
cdb
Clark Bowen
I think you could use the shock tower that comes with the suspension kit used to replace the EAS on a Range Rover Classic.
Not sure if there is room in a D90 for the shock tower and you'd probably have to fab up something for the lower shock mount.
I just saw a picture of a D90 that had separate shock and spring mounts, but I can't find where it was. It was a well done custom setup.
2011 RR HSE -
2001 GMC 2500 4wd
Old February 21st, 2012, 12:23 PM
Landy_Andy's Avatar
Landy_Andy
Andy
You could use some front twin shock mounts like this :
http://www.lrparts.net/pp/DEFENDER/S...MOUNT_KIT.html
Front spring retainers, where? artm Defender Technical Discussions 11 September 17th, 2005 01:12 AM
Need D1 rear spring perch James Wanted 1 April 3rd, 2005 12:29 AM
Spring spacers rvrchuck Defender Technical Discussions 4 July 29th, 2004 10:46 AM
Spring Isolators wicks Defender Technical Discussions 16 January 28th, 2004 02:37 PM
