X-eng Deflex clearance 110 - Defender Source
Old December 17th, 2015, 04:56 PM
D90user's Avatar
D90user
steve
109/110 ambulance-55 series I
I'm hobbling together a Deflex kit that was... Shall we say, less than usable.
Among other things I replaced 1 ball joint and some bushings but I noticed on axle drop the 'knuckle' hits the spring perch. No matter what I adjust I can't get it to not hit.
I was supplied with a cut up mounting block (frame side) so I have no clue what it is supposed to look like.... Anyone have a picture of a pre td5 110 one?
I'm running HD ome springs that are a little wider but not much more than LD HD.
Any input would be great. I leave for a trip in a week and the way it is now it would certainly get eaten by Baja.
I
Old December 17th, 2015, 05:29 PM
SafariHP's Avatar
SafariHP
Safari Heritage Parts
1983 Defender 110
I
Simple fix is to throw the crap away for you can also bend the 2 rear arms equally.
ID:	137331   Click image for larger version
ID:	137333   Click image for larger version
Name:	DSCN2432 - Copy.jpg
2450 North Forsyth Rd
Winter Park, FL
(407)517-4983
Old December 17th, 2015, 05:37 PM
D90user's Avatar
D90user
steve
Hahaha!
Tempting I've got way too much time into this.
Old December 17th, 2015, 06:16 PM
D90user's Avatar
D90user
steve
Have you had any troubles with it bending further because of the bend?
Old December 17th, 2015, 09:15 PM
Never seen one on a 110, but on a 90, the right side arm should be shorter than what you have pictured.
Basically, the right side arm should swing up behind and under the right rear spring perch.
Your right side arm just looks too long to me, but like I said, I have no idea what the 110 one should look like.
Old December 17th, 2015, 10:03 PM
fishEH's Avatar
fishEH
Brett Fritzler
94, 95, 96 D1's
Aren't 110 rear springs a larger diameter than 90 springs? Couldn't that be a contributing factor to the interference?
Old December 17th, 2015, 11:01 PM
the rover shop
shayne young
I've got that setup on my 110 and am about to pull it off and put it on my 130.... I'll get some pics of the setup on my 110 in the morning and post em up..from memory it was a pain to setup, but can't recall why...and yes, 110 springs are bigger than 90.
Old December 17th, 2015, 11:07 PM
All springs are the same outside diameter. It does not matter the brand. 7" od for 110/130 rears.
Go and search on AULRO forums. There are a ton of discussions there.
Old December 17th, 2015, 11:21 PM
Fred Lobster's Avatar
Fred Lobster
Pete Gerbine, III
1993 110 (#451)
To me, it almost seems like an offset spacer where the sway bar attaches to the frame brackets may help....moving the bar further away from your axle, and pulling the arms further away from your spring perches.
Not sure if bending the arms or offsetting will help my situation... The tops of my arms are hitting my frame and the sway bar shifts a few inches in either direction. I believe hitting the frame has caused the left piece of the sway bar to bend inward slightly, as seen in the pic. I am running TF HD springs and have a RTT. Was hoping this would drastically reduce the body roll, but having some doubts in either the TF shocks and springs, the X-Deflex set up, or my ability to put it together, because it almost seems like things are getting worse on the highway.
ID:	137375   Click image for larger version
Old December 17th, 2015, 11:54 PM
the rover shop
shayne young
Heavy duty coils have a 20mm spring coil..standard duty have 18mm spring coil..
Old December 18th, 2015, 10:53 AM
D90user's Avatar
D90user
steve
I dont have them to measure right now but the heaviest OME rear springs sit slightly off the perch and are slightly wider them LR HD.
Interesting, and concerning... Perhaps a polybush cut as a space on either end to limit the sideways movement of the bar?
I may do that just in case.
I'm going to bend the bar per Stephens advise and will report back.
Old December 18th, 2015, 10:57 AM
the rover shop
shayne young
I put this system on my 110 for exactly the same reasons, and it worked great to reduce the body roll..adding dual shocks on the rear helped also as it tended to slow down the inertia effect of it tipping... From memory there is a very specific way of adjusting the distance of the 2arms apart from each other...do you have the installation instructions for the system.?.
Old December 18th, 2015, 12:11 PM
Wolf Fabrication's Avatar
Wolf Fabrication
Sterling Archer
'08 D3
Just email the guy who invented it and let him know your issues:
Simon Rafferty: simon.rafferty@x-eng.co.uk
Semper Fi!
Old December 18th, 2015, 12:30 PM
X eng deflex kit - Page 2 - Australian Land Rover Owners
Old December 18th, 2015, 12:45 PM
D90user's Avatar
D90user
steve
Thanks. Looking at that thread, their links look to contact the perch also.... strange.
A gusset on the curved bar is certainly needed.
Old December 18th, 2015, 01:02 PM
the rover shop
shayne young
I've got a good inch clearance on each one....
Old December 18th, 2015, 01:05 PM
the rover shop
shayne young
Sorry, try this..
the rover shop
shayne young
Left side..
Old December 18th, 2015, 01:06 PM
the rover shop
shayne young
And of course...from behind...
X Deflex Anti Roll Bar Bill Larson Smaller Projects 23 September 16th, 2016 08:20 AM
X Eng X Deflex Anti roll Bar (with pre Td5 90 Adaptors) mark511 For Sale - Parts 47 November 30th, 2015 02:48 PM
SPAL 11" Electric Fan and X-Eng X-Fan Kit crown14 For Sale - Parts 2 February 5th, 2010 01:12 PM
What's a good condition 90 frame w eng trans go for SafariHP For Sale - Parts 3 May 15th, 2008 03:43 PM
Check Eng Code 1138...any ideas ??? C-Delta Defender Technical Discussions 1 August 9th, 2004 03:50 PM
