X-Deflex alterations to fit a Defender 90 TD5/NAS? - Defender Source
Old February 17th, 2016, 05:59 PM
WestCoastRover's Avatar
WestCoastRover
Jeff
2000 TD5
Red face X-Deflex alterations to fit a Defender 90 TD5/NAS?
I want to purchase the X-Deflex rear anti-sway bar from foundry4x4 . It is designed to fit the 110. The Fuel tank on a NAS 90 and TD5 90 hang much lower and required modification.
I have a 4" lift and 35's on my 2000 TD5 90. What are the modifications/additions I need to do? In 1 year I will remove it and install on my TD5 130 so I don't want to butcher it.
Hope you can help.
Old February 17th, 2016, 06:12 PM
I wouldn't buy one right now then. What's the motivation and actual need?
Old February 17th, 2016, 06:24 PM
WestCoastRover
Jeff
2000 TD5
I use the Defender on knarly trails, but also often cruising a lot of mountain highways at 90km/hr as well. Having no sway bar installed with soft shocks and springs can actually be stressful at higher speeds.
Old February 17th, 2016, 06:29 PM
Capt Milks's Avatar
Capt Milks
Defender V-8, Defender 2.25
Have you looked at a used discovery rear sway bar.
Land Rover 110
Old February 17th, 2016, 06:33 PM
WestCoastRover
Jeff
2000 TD5
I would imagine I'll need mods on it, plus The X-deflex is 4x stiffer than stock and disconnects for when you hit the trails...
Old February 17th, 2016, 11:00 PM
myoverlandrover's Avatar
myoverlandrover
josh
109
Best mod I did to my 110. Contact Simon the owner/designer of it, he'll be able to help. Pm ing you his info
Defender 110
Old February 18th, 2016, 04:54 AM
There is a d90 adapter needed.
Old February 18th, 2016, 01:09 PM
CDN38's Avatar
CDN38
Scott Pelly
2000 110 TD5
Jeff, if you put that on the rear, and don't have anything on the front, it's going to handle worse than it already does.
Just think about throwing it into a corner, the rear stays flay and the front outside corner takes a 6" dive... talk about stressful...
Old February 18th, 2016, 01:14 PM
Wolf Fabrication's Avatar
Wolf Fabrication
Sterling Archer
'08 D3
Originally Posted by CDN38 View Post
Jeff, if you put that on the rear, and don't have anything on the front, it's going to handle worse than it already does. Just think about throwing it into a corner, the rear stays flay and the front outside corner takes a 6" dive... talk about stressful...
I disagree. I ran the x-deflex in the rear with a 5" lift on my 110. No front sway bar. Made a HUGE improvement in handling, especially on corners.
Semper Fi!
Old February 18th, 2016, 01:17 PM
CDN38's Avatar
CDN38
Scott Pelly
2000 110 TD5
Interesting... if you look at any vehicle that comes with 1 swaybar, it's always fro nt.More control to the steering end one the vehicle, which also is prone more to roll more due to additional weight of the engine.
Old February 18th, 2016, 01:19 PM
Sway bars don't work that way. It will, however, increase oversteer. Body roll should be managed. I doubt it will really matter as anyone driving a 90 with a 4" lift on 35s fast enough to be anywhere near the traction limit on pavement will be dead soon enough.
There are problems with the links on these failing with long travel suspension. Something to be aware of.
Old February 18th, 2016, 01:35 PM
WestCoastRover
Jeff
2000 TD5
I have heard the front sway bars on defenders are factory fairly soft as the suspension design is already fairly stable to start, but the rear is the bigger player and is significantly better if in place and stiffer is better if lifted on pavement.
I talked to Simon that designs the X-Deflex, he said with two simple fabricated brackets it can fit a NAS 90 and TD5 90.
I have also heard of Riggin up a D2 Active Corner Enhancement front sway bar (removing the electric/air portion, and having the valve block on a switch) Very cool.
If anyone else has sway bar options or opinions I loved to hear them. Front or rear. Sources to buy as well. Prefer it as a disconnect, and I'm not sure a lift bracket with the stock bar will be affective enough, maybe ok for the front.
Old February 18th, 2016, 01:36 PM
CDN38's Avatar
CDN38
Scott Pelly
2000 110 TD5
stressful = understeer or oversteer. I suppose it would be better to know which is occurring? With 35's and that lift, I'm sure it's all over the road.
Adding only a rear swaybar will reduce understeer.
"Sway bars don't work that way."? It's lateral tortion. With a 4" lift, and no sway bars, if you are cornering at highway speeds, you better believe that the outside edge of the vehicle will drop (AKA body roll). With only a sway bar on the rear, you will have less body roll, but still more in the front than rear.
Agreed, not a rig you want to be doing highway speeds in on a winding road.
90, defender, defender 90, flex, nas, td5
X Deflex Anti Roll Bar Bill Larson Smaller Projects 23 September 16th, 2016 08:20 AM
X-eng Deflex clearance 110 D90user Defender Technical Discussions 18 December 18th, 2015 01:06 PM
X Eng X Deflex Anti roll Bar (with pre Td5 90 Adaptors) mark511 For Sale - Parts 47 November 30th, 2015 02:48 PM
Which doors fit will fit my '85 Ninety? Paul K Defender Technical Discussions 10 October 21st, 2015 07:29 PM
How to fit Td5 dash to 83 110? Gkase Defender Technical Discussions 10 April 9th, 2010 12:28 PM
