WTK how to wire a d90 - Defender Source
Old March 28th, 2014, 10:56 PM
beast's Avatar
beast
the beast
2003/Defender 90
how does one go about re-wiring a D90. It does not have any electrics installed.
Old March 28th, 2014, 11:03 PM
BlackField's Avatar
BlackField
Oscar
D110
Just connect everything like this:
are you starting from scratch? I've considered re doing an entire harness on motorcycles and my super 7 but this would be a tall order but not impossible. Get a couple of sheets of plywood and start running wires. I would break it up in to subharnesses and join them with watertight bulkhead connectors.
Old March 29th, 2014, 06:37 AM
Antichrist's Avatar
Antichrist
Tom Rowe
Defender/Disco/Series/MoD
Check out HP Books Automotive Electrical Handbook (HP 387). I've seen it in libraries.
I has some good information including one or two chapters on wiring a vehicle from scratch.
X2 on going the sub-harness route, makes future repairs/changes easier.
Tom Rowe
Atlanta, GA
62 88 Regular
67 109 6cyl NADA x2
95 DI 5-speed
95 D90 5-speed
97 D1 Automatic
Old March 29th, 2014, 02:29 PM
beast's Avatar
beast
the beast
2003/Defender 90
thanks for the help
------ Follow up post added March 29th, 2014 03:32 PM ------
thanks. this helps a lot
Old March 29th, 2014, 05:57 PM
Landy_Andy's Avatar
Landy_Andy
Andy
If you've got no looms at all, try UK Ebay there are looms on there for sale quite regular. otherwise you could just order a brand new looms direct from Autosparks.
http://www.autosparks.co.uk/index.php?cPath=114
Not the cheapest option but by the time you've purchased the correct wire colors, connectors & loom tape etc.... add in your time there actually a good deal. You also know that they'll be 100% correct too, makes fault finding so much easier down the road
Old March 29th, 2014, 11:50 PM
beast's Avatar
beast
the beast
2003/Defender 90
kool thanks.
90, d90
97 D90 engine wire harness AMR 5713 Shane@EVS For Sale - Parts 1 October 10th, 2011 06:29 PM
Could a loose sparkplug wire cause the D90 to not start? Neil McCauley Defender Technical Discussions 4 August 31st, 2010 08:17 PM
WTK: Value on a D-90 SD roof rack basket Bugeyelen Defender Technical Discussions 2 May 25th, 2009 10:52 AM
Hot Wire a D90 The Wizard Defender Technical Discussions 23 February 5th, 2009 09:42 PM
94 D90 wire harness & 94 A/C wire harness mdmuf Wanted 1 August 24th, 2007 09:33 AM
