WTF... Fourth clutch master cylinder in 5 years ? - Defender Source
Old June 22nd, 2010, 06:26 PM
JFD's Avatar
JFD
Julien Dalbin
05 Tdi 90
Angry WTF... Fourth clutch master cylinder in 5 years ?
Long story made short:
Vehicle delivered january 05, aftet about year and a half, the clutch master cylinder started to leak. I replaced it myself with a new genuine unit. Begining of this year i did a clutch overhaul (faulty lever) so i put also a new master and slave... the damn thing is leaking again.
Do you guys know about an improved unit or a trick to make this part more reliable ?
- Charles Eames
Old June 22nd, 2010, 06:30 PM
WLDKGDM's Avatar
WLDKGDM
Dan Cronin
1997 D90 SW
What type fluid you running? DOT 3,4,5??? LMA?
Wear The Fox Hat.
Old June 22nd, 2010, 06:32 PM
JFD's Avatar
JFD
Julien Dalbin
05 Tdi 90
Motul DOT4.
- Charles Eames
Old June 22nd, 2010, 06:34 PM
Try GTLMA. Make sure it is adjusted properly and lube the crap out of it with brake lubricant before fitting.
Old June 23rd, 2010, 08:24 AM
FlaD90's Avatar
FlaD90
Tom
1994 ST D90
2nd that, it's been 2 years since and no problems
Old June 23rd, 2010, 09:03 AM
ECR's Avatar
ECR
East Coast Rover Co.
Just Defenders, nothing else.
+3
Since we switched to Castrol GTLMA we no longer see repeats of that issue. Don't know why, but they seem to be lasting longer for customers.
Email:
Old June 23rd, 2010, 09:59 AM
JFD's Avatar
JFD
Julien Dalbin
05 Tdi 90
I hope i can find the Castrol stuff down here.
The good part is i can do the cylinder swap
kind of quick and easy, even if the removal
of the pedal is always a little tricky.
I guess the best option for a genuine cylinder is RDS, right ?
- Charles Eames
clutch, master
Clutch master cylinder replacement Trigger Defender Technical Discussions 20 July 8th, 2015 08:01 PM
Clutch Master Cylinder Billakris Defender Technical Discussions 22 November 29th, 2011 03:02 PM
Clutch Master Cylinder Abrooks For Sale - Parts 4 December 2nd, 2009 11:18 AM
Re-Sleeve ing Rear Brake and Clutch Master Cylinder COSteve Defender Technical Discussions 12 June 24th, 2006 12:33 AM
NEW Clutch Master Cylinder 4 Sale roverboy For Sale - Parts 0 October 6th, 2004 10:10 PM
