Wrong Wheel Offset. Spacers good idea. - Defender Source
Old July 13th, 2014, 10:18 PM
samer0214's Avatar
samer0214
Samer Hijazi
1997 P38 Vitesse
My '86 D110 came with the following wheels that had been installed by the PO.
They are the wrong offset, as apparent by the photo, because as you can see, the hubcaps are visibly sticking out, and because when I turn the steering wheel all the way to the left or the right, the tires are rubbing on the inside.
Are wheel spacers OK to use in this situation, or is a wheel swap the only solution? The current tires on those wheels are: Continental Cross Contact AT 235-85/16.
Thank you - Samer
Thank you - Samer
1997 P38 Vitesse (Red)
2003 Discovery II
Defenderless, for now!
Old July 13th, 2014, 10:20 PM
Z.G's Avatar
Z.G
Zack
300Tdi 95 D1
There is a certain group of people on this forum that will buy those wheels off you.
Old July 13th, 2014, 10:22 PM
samer0214's Avatar
samer0214
Samer Hijazi
1997 P38 Vitesse
Kindly school me on those wheels. What model are they? I'm guessing they are 16 x 7? Is that correct?
Thank you - Samer
2003 Discovery II
Old July 13th, 2014, 10:23 PM
You can fix the rubbing issue by adjusting the steering stops.
Old July 13th, 2014, 10:25 PM
Its not that they are the wrong offset. Its that you have an early truck with the large front hubs. This was long before LR ever considered putting alloys on 110's. If your truck is lhd you could upgrade to a 93 up rrc or disco 1 24 spline front axle and you would be able to run alloys with hub caps.
Those are Boost alloys and are prized by some here.
Old July 13th, 2014, 10:27 PM
samer0214's Avatar
samer0214
Samer Hijazi
1997 P38 Vitesse
Unfortunately, mine is RHD.
Thank you - Samer
2003 Discovery II
Old July 13th, 2014, 10:30 PM
Adjust the stops, wear a gold chain around your neck, fold your pizza slice in half when you eat it and you are the newest member of the NYC boost club. Congrats...... I think.
Old July 13th, 2014, 10:31 PM
samer0214's Avatar
samer0214
Samer Hijazi
1997 P38 Vitesse
Dave: Forgive my ignorance, but does that mean that the turn radius will be affected (in this case increased) when you change the steering lock stops?
------ Follow up post added July 13th, 2014 07:33 PM ------
Cruising the wilderness of Rodeo Drive would me more appropriate in this case
Thank you - Samer
2003 Discovery II
Old July 13th, 2014, 10:33 PM
Slightly but I doubt it will be very noticeable. Worst case situation you move them back, return the gold chain and get different wheels.
Old July 13th, 2014, 10:34 PM
samer0214's Avatar
samer0214
Samer Hijazi
1997 P38 Vitesse
What style wheels are those anyways? What are they called? Just curious.
Thank you - Samer
2003 Discovery II
Old July 13th, 2014, 10:36 PM
Boost Wheels
Old July 13th, 2014, 10:40 PM
samer0214's Avatar
samer0214
Samer Hijazi
1997 P38 Vitesse
Thank you Gentlemen. Amazing forum as usual. Appreciate it!
Thank you - Samer
2003 Discovery II
Old July 13th, 2014, 11:28 PM
See post five for the Answer .
Old July 13th, 2014, 11:36 PM
Baldewin's Avatar
Baldewin
Chris Baldewin
Bastard 90
Wheel spacers would solve both his issues I believe.
Old July 13th, 2014, 11:41 PM
Viton's Avatar
Viton
Deaf Ember
Smart 4x4
My concern about changing the steering lock stop settings is that if you allow the wheels to turn tighter (Uncle Doug chime in here), will you over extend/bind up the CV joints and cause excessive wear or breakage to those joints ?
Old July 13th, 2014, 11:51 PM
ArmyRover's Avatar
ArmyRover
Bill Ski
83 110 "Frankenstein"
I had the same issue with the caps sticking out I just put on the spacers and problem was solved for me. No rubbing and no center cap sticking out.
Unknown Author
716-898-8153
Old July 13th, 2014, 11:58 PM
Backwards Dennis. You screw them out further so the allow less deflection..... Less extension.
Old July 14th, 2014, 12:07 AM
samer0214's Avatar
samer0214
Samer Hijazi
1997 P38 Vitesse
Duh! I was asleep at the wheel.
------ Follow up post added July 13th, 2014 09:09 PM ------
Are spacers an issue, just in case I decide to go that way. Turning radius on the 110 because of the rubbing issue is already too wide.
Thoughts?
Thank you - Samer
2003 Discovery II
Old July 14th, 2014, 12:15 AM
ArmyRover's Avatar
ArmyRover
Bill Ski
I run 265/75 on my aluminium wheels (wider tires then you are running) and have no issue with rubbing with the spacers.
Unknown Author
716-898-8153
Old July 14th, 2014, 12:19 AM
samer0214's Avatar
samer0214
Samer Hijazi
1997 P38 Vitesse
Thanks Bill. My question wasn't clear enough. What I meant to ask is: Are spacers reliable? Any issues with them breaking on trails? Might they cause other issues to the suspension?
Finally, which ones are recommended?
Thank you - Samer
2003 Discovery II
ac, fs, wheel
Is there a right and wrong way to lubricate the wheel hubs? Zooraya Defender Technical Discussions 30 July 1st, 2013 06:36 PM
Wiring Fuel Pump to a seperate switch, Good or bad idea? Neil McCauley Defender Technical Discussions 4 September 3rd, 2010 05:20 PM
Good Idea to cover spare tire holes on SW UtahD90 Wanted 8 November 11th, 2008 03:34 PM
110 wheel offset cdb Defender Technical Discussions 1 November 2nd, 2008 10:09 AM
Wanted RHD steering box or a Good Idea ! Moses Wanted 2 September 2nd, 2007 10:26 PM
