Wrong Wheel Offset. Spacers good idea. - Page 2 - Defender Source
Old July 14th, 2014, 12:27 AM
ArmyRover's Avatar
ArmyRover
Bill Ski
83 110 "Frankenstein"
Samer,
I had no issues, I was pushing 6k rpm in 2nd off road slinging mud and basketball sized chunks of turf. Bouncing in and out of rutts and catching solid patches of traction. I was more worried about snapping a CV or axle than the spacer.
------ Follow up post added July 13th, 2014 11:28 PM ------
I went with these spacers and many others have as well with no issues that I have heard of.
http://www.ebay.com/itm/Wheel-Adapte...8f5462&vxp=mtr
Unknown Author
716-898-8153
Old July 14th, 2014, 12:39 AM
Viton's Avatar
Viton
Deaf Ember
Smart 4x4
Originally Posted by javelinadave View Post
Backwards Dennis. You screw them out further so the allow less deflection..... Less extension.
I understand Dave, so I guess I'm changing the initial question to inquire about tightening them in to gain a tighter turning radius, is this harmful ?
samer0214's Avatar
samer0214
Samer Hijazi
1997 P38 Vitesse
Thanks for the link. Just one last question please. Will these work on drum brakes? My truck has drums in the back.
Thank you - Samer
1997 P38 Vitesse (Red)
2003 Discovery II
Defenderless, for now!
Old July 14th, 2014, 12:50 AM
That I don't know.
Old July 14th, 2014, 01:17 AM
samer0214's Avatar
samer0214
Samer Hijazi
1997 P38 Vitesse
Never mind guys. I found the answer in another post. The spacers should work on drum brakes with no issues.
Thank you - Samer
2003 Discovery II
Old July 14th, 2014, 07:38 AM
At the risk of complicating matters, you can change the drums to disks.
Old July 14th, 2014, 08:39 AM
samer0214's Avatar
samer0214
Samer Hijazi
1997 P38 Vitesse
I'm actually contemplating the idea.do you know what is required to do that besides calipers and disks of course?
Thank you - Samer
2003 Discovery II
Old July 14th, 2014, 08:40 AM
ArmyRover's Avatar
ArmyRover
Bill Ski
They work fine on drums my rears are drum also
Unknown Author
716-898-8153
Old July 14th, 2014, 08:52 AM
rather than getting into all that there are a couple threads on here about it. Mark Kelgren did a write up and so did Frank Rafka.
Old July 14th, 2014, 09:03 AM
samer0214's Avatar
samer0214
Samer Hijazi
1997 P38 Vitesse
Searching the threads as I type. Thanks.
Thank you - Samer
2003 Discovery II
Old July 17th, 2014, 09:35 PM
samer0214's Avatar
samer0214
Samer Hijazi
1997 P38 Vitesse
Bill: I ordered the spacers you linked me to, and installed them earlier today. They definitely took care of the rubbing issue, but I have a major concern with them. The lug nuts that came with them do not scream in all the way on the hubs, because the hub studs are too short. Once all in and tightened, I can still see 4-5 threads on the nuts. Is this what yours are like?
Machining the back of the spacers down about an eighth of an inch would help a little bit, but would still keep some threads exposed. Thoughts?
Thank you - Samer
2003 Discovery II
Old July 17th, 2014, 09:57 PM
Daddymow's Avatar
Daddymow
Raub A.
1987 D110 Tithonus
Mine do that with Wolf rims, came like that from the MoD.
Old July 17th, 2014, 11:14 PM
defender1844
Amit Likhyani
Sam, I had the same observation with those spacers as I also had a rubbing issue with 285 tires. If others have had no issues with the spacers I'm sure they are fine but I was creeped out and went with a non OEM wheel that had the offset built in.
Old July 17th, 2014, 11:29 PM
ArmyRover's Avatar
ArmyRover
Bill Ski
Mine did not have that issue i would contact the vendor.
Unknown Author
716-898-8153
Old July 18th, 2014, 12:19 AM
samer0214's Avatar
samer0214
Samer Hijazi
1997 P38 Vitesse
Will do.
Thank you - Samer
2003 Discovery II
Old July 18th, 2014, 08:20 PM
samer0214's Avatar
samer0214
Samer Hijazi
1997 P38 Vitesse
The vendor was no help at all. They kept insisting that I need to change the studs in the hubs. I asked to return the spacers and am waiting to see what they have to say.
Can anyone recommend other "better" spacers they've tried and know to have worked?
Thank you - Samer
2003 Discovery II
Old July 23rd, 2014, 04:52 PM
samer0214's Avatar
samer0214
Samer Hijazi
1997 P38 Vitesse
After further research and reading I think I've found the issue with my hubs. Apparently (as I'm sure many of you know) there are 2 types of hubs: a Standard and a Heavy Duty hub, both with the same length wheel studs, but different thicknesses. The ones with the thicker flange are the HD ones, and the studs don't protrude as much, which makes them unusable with spacers and Alloys.
The spacers referenced above are only compatible with the standard hubs, and apparently, a few on this board bought them and used them with success. As an aside, I also found out that Defender/110 wheels are hub centric, but the spacers above are not. Personally, even if I had the standard hubs, I wouldn't install those spacers, as they are not hub centric, which means that the weight of the wheels is resting on the studs and lug nuts. The proper hub centric wheel spacers are available out there and IMHO, they are the ones to use.
Much of that information comes from this post: http://forums.lr4x4.com/index.php?showtopic=69638. Finally that post alludes to Wolf studs that can be swapped for the "short" studs on the HD axle. My question is: has anyone had experience with this, and where can Wolf studs be purchased, and they easy to swap out?
Thank you - Samer
2003 Discovery II
Old July 23rd, 2014, 05:02 PM
samer0214's Avatar
samer0214
Samer Hijazi
1997 P38 Vitesse
I'm sorry I don't understand. Do you mean all 5" and 6.5" steel wheels are lug centric?
Thank you - Samer
2003 Discovery II
Old July 23rd, 2014, 05:08 PM
Z.G's Avatar
Z.G
Zack
300Tdi 95 D1
He's referring to the bolt pattern
Old July 23rd, 2014, 05:15 PM
samer0214's Avatar
samer0214
Samer Hijazi
1997 P38 Vitesse
Understood now. Thanks. All 5 lugs on 6.5" wide steelies.
But what about Alloys? The ones on my rig now (Boosts) seem to be hub centric, and there certainly are hub centric spacers out there for Defenders?
https://www.motorsport-tech.com/4DCGI/switchtruckmodel
Thank you - Samer
2003 Discovery II
ac, fs, wheel
Is there a right and wrong way to lubricate the wheel hubs? Zooraya Defender Technical Discussions 30 July 1st, 2013 06:36 PM
Wiring Fuel Pump to a seperate switch, Good or bad idea? Neil McCauley Defender Technical Discussions 4 September 3rd, 2010 05:20 PM
Good Idea to cover spare tire holes on SW UtahD90 Wanted 8 November 11th, 2008 03:34 PM
110 wheel offset cdb Defender Technical Discussions 1 November 2nd, 2008 10:09 AM
Wanted RHD steering box or a Good Idea ! Moses Wanted 2 September 2nd, 2007 10:26 PM
