Would this leak on the oil filter housing cause all this? - Defender Source
Old December 17th, 2017, 08:12 PM
kmagnuss's Avatar
kmagnuss
Mag
86' 110 pickup
New to me 86' 110 2.5NA... going through everything and changed the oil, fuel, air filters tonight. Looks like the oil filter housing has a leak at the block... maybe? Do you think that is the cause of all this oil? It's hard to tell from the pic but this is the highest point of the leak and it goes from caked on nastiness to clean (with oil on it) there.
On a side note, it looks like my oil pressure sending unit wire is cut. Do these things even have a need for the sensor? I don't have a light on for it, but it could be a burned out bulb of course.
Thanks.
Mag
Oh ps... is the air intake for the filter supposed to be pointed right at the exhaust manifold? Seemed weird to me so I stuck it in the corner next to the headlight.
Old December 17th, 2017, 09:44 PM
pitchrollyaw's Avatar
pitchrollyaw
wayne p
1985 d90 2.5NA
My oil leak pattern looks surprisingly like that, but it originates from the fuel pump to block 'seal'. I only have ~4k on the rebuild and the leak is minor enough where I live with it, but snugging up the fasteners helped a bit. I'd try that.
As far as the oil pressure light does it light prior to building pressure? Yes you need one and a gauge and light are better.
'85 90 2.5NA
'72 SIII 88"
Couple other cars
..tolerant Wife...
Old December 17th, 2017, 09:56 PM
Naplm00
Matthew
Clean it then look Where the leak is coming from using uv dye. No use guessing
Old December 17th, 2017, 10:11 PM
When something is that negrlected/filthy I usually use a putty knife to scrape the thick nastiness off and then
this product to clean it back to bare metal.
Post the amazon link only to illustrate the product. I pay 3.70 something a can for the stuff.
11 Bucks a can is absurd.
https://www.amazon.com/Berkebile-Oil.../dp/B000CII6JM
Old December 17th, 2017, 11:25 PM
roverman2010's Avatar
roverman2010
1985 LR 90 200Tdi
is the pressure sensor tight? the way the oil starts from that point.
JnK Services
FC101 GS FFR
57 LR 88" SXF 858
85 LR90
95 D1 Tdi
05 D3 HSE
97 XK8 BRG FHC For Sale
Old December 30th, 2017, 06:29 PM
kmagnuss's Avatar
kmagnuss
Mag
86' 110 pickup
Update:
Had a few loose bolts up there... especially the bolts that hold the fuel pump primer on to the engine. Replaced the pressure switch and the wire going to it(the oil light works now). Scraped off a lot of the goo. Pressure washed it with a steam pressure washer (topside of engine only... I had no idea the valve cover was aluminum! Lol).
So far... knock on wood... the leaks seem to be gone. We'll see what it's like in a few days.
Thanks guys.
-Mag
- Tarpon Fishing Charters
"Tarpon... Everything else is just bait"
2.5 Oil Filter Housing gchinsr For Sale - Parts 3 April 5th, 2012 12:02 AM
D-90 air filter housing cap needed (horn) arbik Wanted 4 November 30th, 2010 12:45 PM
Oil leak rustydefender Defender Technical Discussions 19 December 9th, 2004 09:06 PM
