Would PUMA axles be a direct bolt on to NAS 110? - Defender Source
Old April 28th, 2014, 03:28 PM
Neil McCauley's Avatar
Neil McCauley
Neil McCauley
94 ST, 97 ST, 93 110
Question Would PUMA axles be a direct bolt on to NAS 110?
I was replacing the wheel cylinders on my 110 and instead of doing the parts swap, maybe it would be easier just to buy a PUMA axle and do the switch over. Does anyone know if its a direct swap? I would imagine for brake line you just attach the flexible brake line hose.
Robert Deniro
Old April 28th, 2014, 03:43 PM
Yep. Direct bolt up.
Old April 28th, 2014, 03:47 PM
Neil McCauley
Neil McCauley
I would imagine PUMA axles are much better than my old Salisbury? Would it be difficult to source brake pads / rotors etc? Would RDS or Safari parts have one? I appreciate the help.
Robert Deniro
Old April 28th, 2014, 03:48 PM
With the correct length driveshaft (propshaft).... Pumas use Rover rear axles with P38 diffs, so the driveshaft needs to be longer. Most would consider it a big downgrade from the salisbury axle.
Old April 28th, 2014, 03:59 PM
Neil McCauley
Neil McCauley
If I have to extend the rear propshaft forget it then. I thought it was a direct bolt on.
Robert Deniro
Old April 28th, 2014, 04:00 PM
If you got a 300TDI era rear axle, it would be fine. Salisbury center and disc brakes. You can also convert the current axle to disc brakes, if you want.
Old April 28th, 2014, 04:08 PM
http://www.landroverexpedition.com/t...110-rear-axle/
Old April 28th, 2014, 05:32 PM
Neil McCauley
Neil McCauley
Great reading thanks! I think I will stick with salisbury than rebuild with disc brakes since Salisbury is stronger.
Robert Deniro
110, nas, axle, nas 110
Sureterm Direct Insurance- 15% Discount katie.norton The Vendors Loft 0 January 13th, 2010 12:28 PM
Safety Devices Direct? specops1526 The Flea Market 14 September 5th, 2009 04:43 PM
Is a D2 transfercase a direct replacement? phoenix37 Defender Technical Discussions 19 July 31st, 2009 07:37 AM
Distributorless (direct ignition) system nikojo Defender Technical Discussions 2 November 11th, 2008 01:44 PM
What is the direct web address for the forum? TDI Guy Support & Suggestions 3 January 4th, 2008 05:59 PM
