Won't Turn Over - Defender Source
Old July 21st, 2016, 05:16 PM
RAKinsler's Avatar
RAKinsler
Robert Kinsler
1986 Defender 110 RHD Diesel
Won't Turn Over
Soooo, trying to go to the Happy hour and of course today is the day the rig wont turn over.
Sounded like there was no juice to turn over the starter but the lights are bright, the radio strong, so it doesn't seem like that is it (at least from my other dead batteries).
This has happened once before and after a couple hours (including about 30 minutes of trying to jump it with no luck) the rig turned over randomly.
Any ideas of what I need to wiggle, jiggly or otherwise plead with? Kinda frustrated right now.
Father of Two, Husband, Business & Defender Owner
Old July 21st, 2016, 05:19 PM
AdamSanta85's Avatar
AdamSanta85
91' D90 200TDI
It could still be the battery. I have had batteries die suddenly like that. Literally never a problem, to completely dead.
You can try giving the starter a hit with a hammer too
If you have a volt meter check voltage between positive and negative. Also check voltage at the hot lead on the starter. >= 12.6v If there is no juice there, check on the starter solenoid. If that is good check the ground by probing negative terminal to starter body.
You hear a click?
Old July 21st, 2016, 05:25 PM
Brewie212's Avatar
Brewie212
Brian Kandefer
If you have a test light put it on the little spade on the starter, turn the key and see if the test light lights up. If it does the starter is bad, you can roll start it or try hitting it with a hammer...
Old July 21st, 2016, 06:09 PM
rdavisinva's Avatar
rdavisinva
Guess Who?
N/A
Brian mean hit "it" the starter with a hammer, not the windshield, we know it is frustraiting.
We still have a few of the 3.1 KW starters that will spin the engine like a sewing machine and they also fit the TDI engines if/when you upgrade
RDavisinVA
Old July 21st, 2016, 06:31 PM
deanclean's Avatar
deanclean
Ryan Stevens
1995 Defender 300tdi
This happened to me on an old mini truck I had. It would start fine most times then just randomly not. Turned out i just needed to add some copper washers to the battery terminals. I don't know a ton about cars but I guess this just helped make better contacts. Its something easy you could try anyway.
Old July 21st, 2016, 08:03 PM
carlosz's Avatar
carlosz
Carlos
possible ignition switch failure?
the truck ran like a "raped ape"
A fussy warm weather creature...
Old July 21st, 2016, 08:17 PM
Brewie212's Avatar
Brewie212
Brian Kandefer
using the test light to the spade on the starter will tell you that, if there isn't a light then it's between ignition switch and spade, if it lights then it's the starter.
Old July 22nd, 2016, 12:06 AM
RAKinsler's Avatar
RAKinsler
Robert Kinsler
Welp, I guess I learned that in a diesel that needs good cranking you can still have enough juice to run the lights full bore, and radio without weakness but not have enough to turn over the engine.
Replaced the battery and all is right with the world. Bummer it caused me to miss the NOVA Rover HH tonight though
Thanks for all the tips everyone!
Wet D90---> won't turn over EnduroPro Defender Technical Discussions 11 February 10th, 2016 08:36 PM
1986 17H Turns Over But Won't Start willhahn24 Defender Technical Discussions 0 September 13th, 2014 11:14 AM
Help! Cant get the key to turn over hotroddef90 Defender Technical Discussions 10 October 27th, 2012 04:51 PM
Won't turn over gtg067i Defender Technical Discussions 6 September 27th, 2009 09:18 PM
Engine turns over but won't start bd90 Defender Technical Discussions 9 August 8th, 2008 12:22 PM
