won't turn off - Defender Source
Old July 4th, 2010, 05:07 PM
jjstahl3's Avatar
jjstahl3
Jay S
96 D1 TReK
won't turn off
last night engine would not turn off - I assume it is the fuel shutoff solinoid? where is it what else could it be? what would I have to replace the entire fuel pump? any and all help would be appreciated
Jay
Old July 4th, 2010, 05:20 PM
Probably the ignition switch.
Old July 4th, 2010, 05:31 PM
jjstahl3's Avatar
jjstahl3
Jay S
96 D1 TReK
can i get in there and clean any contacts or should I just replace it? rovers north has 2 how do I know which one to get?
http://www.roversnorth.com/store/p-1...e-petrol-.aspx
or
http://www.roversnorth.com/store/p-8...clmn-lock.aspx
thanks
Jay
Old July 4th, 2010, 05:36 PM
I don't know about which one to order. The NAS one with the chime is like 3x as much as the ROW one. try wiggling the key. You have to pull the dash cluster and then you can see if you are still getting power from the switch when it is off (they fail internally). Careful not to break the speedo cable when you pull the dash cluster.
It could be a short elsewhere, but that would be my first guess.
Turn Signal Failure arbik Defender Technical Discussions 53 October 11th, 2010 10:51 PM
Anyone have the turn signal Wagner/Bosch part number? arbik Defender Technical Discussions 5 February 2nd, 2008 10:33 AM
Euro style front turn indicators boshea Defender Technical Discussions 12 September 22nd, 2005 07:56 AM
Turn signal--problem solved Davis Defender Technical Discussions 0 July 18th, 2004 08:13 PM
